09-17-2007, 01:15 PM | #1 |
Windshield Washer Fix
Small issue compared to most of the probs in the forum, but vexing none the less. I have rebuild kits for the stock washer pumps, but seems like a pain to get to the motor/pump to remove (any helpful hints there), and past pump kit rebuilds were not always successful.
Also am looking at aftermarket replacement pumps (as in LMC and Whitney catalogs) that mount in front of firewall separate from the motor and supposedly are an easy install using connection to existing motor/pump wiring. Any experience and suggestions/preferences there? All assistance will be appreciated. Thanks. CCCC
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
09-17-2007, 01:23 PM | #2 |
Re: Windshield Washer Fix
I've got a universal pump from Kragen, it was simple to wire up.
09-17-2007, 03:32 PM | #3 |
JUST PULL THE DASH CLUSTER AND YOU can get to it.
I BELIEVE IN JOHN 3:16 |
09-17-2007, 03:53 PM | #4 |
dont know about the rebuild kits in the past i ust bought the replacement pumps from lmc like said drop the inst cluster and its not too bad to replace the pumps held up well with no problems
09-17-2007, 04:03 PM | #5 |
Sisyphus was my mentor!
I have installed the combined washer jug/pump out of Chevy Caprices. They hold 4 liters of washer fluid (WAY more than factory) & all thats needed to activate it is a simple momentary contact switch. I mount the switch in the 1/2" hole in the bottom of the dash near your left knee. Sooo much better than the factory's sprayer that goes along with the wiper motor with the "kachunk-kachunk-kachunk" sound.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
09-17-2007, 10:51 PM | #6 |
Go to the parts store and get a whole new pump, they will probably have to come from the warehouse. It will be made by anco, same as oe. The one lmc sells is an anco pump just usually more than what you can get at the part store. I know oreilly auto parts has them. And as stated above just remove the cluster.
09-18-2007, 12:47 AM | #7 |
Thanks gentlemen - helpful info that will do the trick.
CCCC
09-18-2007, 12:52 AM | #8 | |
Chief Honcho In Charge
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
09-18-2007, 07:09 AM | #9 |
Old member
Here is my fix. I bought the jug at the local yard. It's off a little farn job. Anything can work. I wired it up to the factory switch. It works great.
I put the spray nozzeles in hot water on the stove and put vise gripes on them to close them up enough to hold onto the wipers.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-18-2007, 07:13 AM | #10 |
i looked on my laptop here, but i dont have any on this computer - they are on my desktop in Winnipeg. I can say that its attached by 2 bolts to the innerfender near the factory one. The Caprice bottle is curved on the bottom to match the curvature of the innerfender. It fits like it was meant to be there. I ran the hose to a "t" under the dash & wired up the pump to a switch. the pump itself is the same pump as in Andy4639's post.
09-20-2007, 11:25 PM | #11 |
What year Caprice should I look for at the junkyard?
Thanks!
--------- 72 SWB K10 San Diego CA |
09-20-2007, 11:39 PM | #12 |
S10 jug and pump look similar. May be the same or a bit bigger... I plan to bolt mine to the left fender about where the original was and wrap the wire into the existing harness with harness (not sticky) tape.
09-21-2007, 12:01 AM | #13 |
The Original HotRod KnifeMaker
I just found one at the wrecking yard that had the pump inside the bottle.
Drilled two holes, mounted it with two screws, connected the wires and the hoses- done deal, works perfectly. Also installed one of putters delay wiper switches- that works great too
Dave 69 GMC SWB 2WD 454 Turbo 400 |
09-21-2007, 08:08 AM | #14 |
I get my washer bottles usually from 91 & up Caprices....
09-21-2007, 09:01 AM | #15 |
So where is the original bottle located in a 71?
09-21-2007, 12:43 PM | #16 |
If it's like a '69 it's here;
Didn't know anybody actually had a working one.Guess I'll fix mine now.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
09-21-2007, 04:33 PM | #17 |
That is where my 72 is
09-21-2007, 05:47 PM | #18 |
When I bought the truck it was bolted to the right fender? I've seen brackets but had no idea where it belongs. I'd rather move it.
09-21-2007, 09:41 PM | #19 |
newly minted old timer
i did a in depth post on this years back, not sure where it went though. its really an easy job. i just use an after market pump. wired it right to the stock switch. works great. im sure i have the photos of where to plug everything in if anyone wants to see..
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
01-24-2016, 11:36 PM | #20 |
Bought this pump from Amazon: Amazon.com: Trico 11-100 Spray Universal...
Stripped the factory unit down to the metal mount bracket Cut off the plastic mount because it was too wide for the bracket. Mounted to the bracket with an Adel clamp and connected to factory wiring.
69 K10 SWB Project Dream '69 2011 K2500 Silverado Beat to fit, Paint to match Dream '69 Build Thread |
09-04-2020, 08:25 AM | #21 |
Mr. Cheyenne
@lawest is mounting on the driver side wiper motor and using the factory mount for the OEM pump?
I have attached a photo from another posting, is this how it looked before you put on the Universal one? Still working okay? I like this approach as it is "near" original and not routing wires to a external pump.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
09-04-2020, 09:41 AM | #22 | |
The Older Generation
I am not the OP but there is only one wiper motor, and that is what the original washer looks like after you remove the plastic cover. Many people that are trying to get their windshield washers working don't think to disconnect all of the hoses and blow through them with an air hose. You have to blow through the nozzles backwards and sometimes you have to use a small stiff wire or torch cleaning tool to get them opened up. After you get everything clean and fill the water jug you have to prime the pump and hoses. I use a turkey baster to gently fill the hoses and pump while someone keeps pressing on the pump switch to activate the pump.... If the pump diaphragm is bad this won't work, but many times it will. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 09-04-2020 at 09:03 PM. |
09-04-2020, 10:05 AM | #23 |
Mr. Cheyenne
ah, only one wiper motor - I clearly did not catch on to that. For the record all I hear is a "tick, tick, tick" when I engage for washer pump. Thank you for your information!
09-04-2020, 10:19 AM | #24 |
Old member
The easy way is to buy a junkyard washer jug out of a late model truck are car and install it. Wire it to the original switch and your done. You have to not care if it's correct for the truck also. I have late model jug & pumps in the 71 & the ramp truck.
I like things to work and work well. So adding newer things is OK with me. I want the stuff to make driving the truck a pleasure.
09-04-2020, 10:30 AM | #25 | |
LockDoc
