Old 09-18-2007, 11:08 PM   #1
energiesource
Cab repair panels, what do i need?
I'm taking my truck apart slowly but surely, and I got the carpet out and yeah... considering this is the only place there is rust its not too bad but thats alot of work, what panels would i need? links would be preferable.
thanks
PASSENGER SIDE( looks like surface rust, should be fine to grind it down i think)
REST ARE DRIVERS SIDE
energiesource is offline   Reply With Quote
Old 09-19-2007, 01:10 AM   #2
TravisH
TravisH's Avatar
Re: Cab repair panels, what do i need?
first thing you need are ebfabman's videos www.ebfabman.com
For your pass side its hard to tell from the pics, could be surface rust but it looks rough. Only thing you show is the floor pan so hard to judge on what it'll need.
Driver's side you'll be after front floor panel, outer rocker and kick panel. Depending on the damage and your skill you'll probably need the rear floor panel as well. Looks like some rust on the lower front of the door so you may need an outer and inner panel for that, again pics don't really show. The condition of the lower A and B pillars isn't seen but odds are good they'll need replacing as well.
I don't think anyone makes a patch for the top of your cab but that looks like a fairly easy fix.
How are your cab corners?
TravisH is offline   Reply With Quote
Old 09-19-2007, 08:02 PM   #3
energiesource
cab corners just look like surface rust, im getting the cab media blasted soon so im sure that all will show. unless i should repair the panels before i do the media blasting?
Old 09-19-2007, 11:58 PM   #4
TravisH
TravisH's Avatar
media blasting first will show all your trouble spots and make it a lot nicer to work on
Old 09-20-2007, 01:05 AM   #5
energiesource
wont make things worse? i mean i know i gotta cut most of the rust out anyway, or sand it down, but it would worsen things that are already bad?
Old 09-20-2007, 01:16 AM   #6
ksjh1316
ksjh1316's Avatar
I think the blasting is the only way to go it will save you more time by showing you the true areas that need attention with no suprises. In my opinion its the only way to get rid of all the cancer before you start the build and to make sure its gone for good.
ksjh1316 is offline   Reply With Quote
Old 09-20-2007, 10:16 AM   #7
Bucky71
How do the cab mounts look?
Bucky71 is offline   Reply With Quote
Old 09-20-2007, 08:39 PM   #8
energiesource
not sure yet, stil trying to get the bed apart, so once i do and get more room at the side of my house ill check. from the interior though, the middle of the cab is spotless, no rust whatsoever.
Old 09-21-2007, 01:05 AM   #9
TravisH
TravisH's Avatar
Rust isn't structural. The blasting might show you some spots that need to be fixed but wouldn't you rather find out sooner than later?
Good call on the mounts though Bucky71, I forgot all about them.
Old 09-22-2007, 06:12 PM   #10
energiesource
so i took some more photos, here they are
drivers side looking forward
drivers side rear cab corner
drivers side again
drivers side floor
passenger side floor, there is a hole right through
