Old 09-19-2007, 08:32 AM   #1
tclaremont
How can I use 71 door panels on my 72?
Is there some sort of fastener that will allow me to use 71 door panels on my 72 doors? The holes in the door are about three times bigger than the holes in the door panel.
I bought the entire interior because it had already been recoverd, etc. So, if I can make use of these panels it will really help alot.
tclaremont is offline   Reply With Quote
Old 09-19-2007, 08:43 AM   #2
aventur1
aventur1's Avatar
Re: How can I use 71 door panels on my 72?
I like the looks of the 72 and am thinking of putting 72 on my 71, good question maybe I can sneek in and get a answer also.
aventur1 is offline   Reply With Quote
Old 09-19-2007, 08:53 AM   #3
prg machine
prg machine's Avatar
I made a bunch of inserts with the proper threads to tack in their place. I think the factory used a push nut made of plastic maybe. If you know someone with a lathe it's a piece o' cake to make them.
prg machine is offline   Reply With Quote
Old 09-19-2007, 09:02 AM   #4
jorgensensc
jorgensensc's Avatar
THere are plastic inserts that go in the holes on the '72. They look square with the hole in the middle IIRC.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 09-19-2007, 09:48 AM   #5
RShaips
The window regulators have a longer shaft on the 72's, if you put 71 door panels on, your handle will stick out about a 1/2" more unless you change out your regulators.
RShaips is offline   Reply With Quote
