Old 09-19-2007, 06:03 PM   #1
Frizzle Fry
Frizzle Fry's Avatar
It's Leaf Guard Time!!!
I got the basis for idea from Putter (thanks buddy!). Since I've had to fish a couple leaves out of my cowl already this week I decided it was time to put up a fight before they all come raining down...
I built this in such a way that I didn't have to modify the cowl at all because I have a radio delete cowl I want to use at some point.
I bought this expanded metal at Home Depot a few months ago. It was less than $10 (and no, it's not 1/2" thick...).
The length (24") is perfect for using two sections joined under the center rib. For the width I used about 4". I curved them slightly, cut holes for the wipers and washer nozzles, then joined them:
Instead of just putting the screws through a convenient opening I decided to cut out the areas surrounding the screw holes and weld in some 20 gauge sheet. This allows the cowl to be mounted properly without being excessively raised by the guard. I marked the holes to be drilled from the other side:
Next I made Z tabs from the same sheet, welded them in place and drilled holes:
Frizzle Fry is offline   Reply With Quote
Old 09-19-2007, 06:04 PM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: It's Leaf Guard Time!!!
sweet, no more leaves.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 09-19-2007, 06:07 PM   #3
Frizzle Fry
Here's how it sits under the cowl. The Z tabs just get sandwiched into the hood/cowl seal:
Installing cowl:
All back together:
BWWWAAAAAAAAHAHAHAH!!! Not this time suckas!
Old 09-19-2007, 06:13 PM   #4
Frizzle Fry
I think I'll paint it flat black.
Old 09-19-2007, 06:14 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Nice work.
I have a friend who has owned and done body work on a buncha these trucks. One thing he suggested to me on my truck was to open up the plenum, with the fenders off. Then, cut a huge X large hole in the bottom. Doing so will let anything that makes it through the plenum, fall all the way out of the cab. Of course, unless you're pulling the fenders, this is a lot of extra work.
The Mustangers' (i.e., 64.5 to 68) have plastic covers available to them that seal the plenum from any water that may fall. I wish we had them available to us, too. What I'd like to have would be made from Lexan, for instance, and curved to fit the contour. You could use some J-hooks with wing nuts to hold the panel in place. Wouldn't have to leave it on all the time, just when you felt like it would be the right thing to do. Using some foam weatherstriping to protect the finish would be needed, too.
Member Nr. 2770
Old 09-19-2007, 08:51 PM   #6
wibilly
wibilly's Avatar
nice job looks real good. i need to make one too but i need somthing to keep the pine neadles out too
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 09-19-2007, 09:16 PM   #7
72freak
Rottenwood Garage Member
72freak's Avatar
Good luck..............that wont happen!!!!!!!!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 09-19-2007, 09:36 PM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Mine has the stainless ones available from the BB vendors.I think they ran about$40.00 but are stainless.They install the same way and are small enough to stop most of the pine needles.I've had them on about three years and can't see any rust and still have good drainage.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-19-2007, 09:40 PM   #9
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Cool Mike, they turned out great!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-19-2007, 10:16 PM   #10
LawMan02
Junior Member
LawMan02's Avatar
I also built my own using aluminum gutter screen. You can get it at most hardware stores in a roll and it's cheap. It's also easy to cut shape and it doesn't rust. Randy
1972 GMC K2500, stepside, stock 350, 4 speed. Former F/D truck with 32,000 miles, no rust.
1973 Jeep CJ 5, 304, 33's with side pipes
2008 GMC 2500HD, CC, SWB, D/A, SLT
LawMan02 is offline   Reply With Quote
Old 09-19-2007, 10:19 PM   #11
LawMan02
Junior Member
LawMan02's Avatar
Forgot the pic:
Old 09-19-2007, 10:26 PM   #12
bad6772
Official Site Guitar Shredder
bad6772's Avatar
looks good frizzle, and good fab skills.....execellent. work
bad6772 is offline   Reply With Quote
Old 09-20-2007, 01:22 AM   #13
Brad
Out of the carpool lane.
Brad's Avatar
Great Tech Tip Mike!
I prefer the smaller aluminum window screen and have mine epoxied in place. It catches most everything but the smallest of stuff.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 09-20-2007, 07:11 AM   #14
70c10
67-72 Addict!
70c10's Avatar
Great write up Frizzle!. Lawman- how did you attach yours?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-20-2007, 08:03 AM   #15
68c-10
I used regular plastic screen like for a window screen. I attached it to the cowl with hot glue, it has been on there for 6 years now and I have not had any problems. It is nice because the holes are smaller and keep even little items out.
68 Chevy C-10 custom, 350,4bbl, serp belt swap, th400, 5 lug disk conversion, added honda seats and factory tach.
71 Gremlin X, 360, t-5, 8 3/4 rear, and dodge dakota seats.
82 Spirit, 4.0,ax-15, 8.8 rear and sti bucket seats
68c-10 is offline   Reply With Quote
Old 09-20-2007, 08:20 AM   #16
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That looks great and actually serves a purpose.
2 birds with 1 stone!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-20-2007, 09:24 AM   #17
lks dcvn
lks dcvn's Avatar
Looks good Mike - thanks for sharing the details and the photos of the process.
I used the black fiberglass (door) screen and used the mounting screws/bolts to hold it in place.
I removed the cowl - cleaned all the junk out of there - then using one long sheet - cut the screen down to match the shape of the cowl and then placed the cowl panel over it - and then bolted it down - nothing in the cowl since then - including pine needles, etc.
It does somewhat (as in slightly) restrict the airflow into the cab when using the kick panel vents, but not enough for me to complain about - especially when I am not cleaning the cowl out all the time...
Although mine does just sit in the garage when not being driven...
lks dcvn is offline   Reply With Quote
Old 09-20-2007, 09:31 AM   #18
dave3156
I used the aluminum gutter guard with a real fine mesh and used clear caulk to attach it. Works great. Two years no problems. Don't have a welder. My kid is in welding school now so soon it will be time to attack the rust!
dave3156 is offline   Reply With Quote
Old 09-20-2007, 09:40 AM   #19
Putter
More Cowbell....
Putter's Avatar
Not a problem. Thanks for the props. I see you took yours a step or two past my idea (no mounting tabs for me). I just cut mine to shape and attached to directly to the cowl with black RTV.
Here's my pic....
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 09-20-2007, 04:38 PM   #20
Frizzle Fry
You guys have me thinking about maybe gluing some finer window-type screen on top of the guard after I paint it. I don't seem to have a pine needle problem but it wouldn't hurt. I may also look into Cheloray's suggestion off opening up a trash escape hole when I have the fenders off. Probably not needed now, but we'll see.
You guys with the aluminum screens; I have to admit they look good left silver colored.
Old 09-24-2007, 11:03 PM   #21
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Nice
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-25-2007, 01:27 AM   #22
Brad
Brad's Avatar
Mike, if you're going to the cruise on Wed, take a look at mine. I'm using black fiberglass screen door mat'l that I got at Parkrose Hardware. It comes on a 60" roll and I just got 7" of it. 60" just covers the width of the slots. I just glued mine on.
Old 09-25-2007, 08:03 AM   #23
Gray Ghost
Gray Ghost's Avatar
Great idea....thanks for posting that....
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 09-25-2007, 11:31 PM   #24
crzngmychvy
"1972 C5"
crzngmychvy's Avatar
You are still a ninja. I you ever get around socal let me know because it would be great to cruise with a person with your skill and along side a truck like yours. One of my favorites, and it's not even done.
- 72 2wd Blazer ...sold...
2wd Blazer Page
crzngmychvy is offline   Reply With Quote
Old 09-26-2007, 12:08 AM   #25
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
My '72 had a set on it when I bought it. Couldn't say if the PO made them or bought them somewhere. Look and work nice though!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
