Old 09-20-2007, 08:35 PM   #1
jott_06
Camaro Club
jott_06's Avatar
You might wanna check the inside of your seat
So i was sitting there in the garage on the seat out of my 68 working on making a patch panel when my nephew notice in the backside of the seat there was a paper which he thought was a reciept for something. I got up and looked and it was the original build sheet/option sheet for my truck from 1/16/68 stuck between the springs and the padding in the backside of my seat. I fished it out but its brittle so i had to tape a few spots back together but i'm going to get it laminated. It's pretty cool to see what all my truck came with from the factory and sort of disappointing to see what all options that the previous owners have removed. Does anyone know if that paper was supposed to be there?
jott_06 is offline   Reply With Quote
Old 09-20-2007, 08:37 PM   #2
Ace in the hole
Re: You might wanna check the inside of your seat
I have heard that it is not uncommon to find them there. Nice surprise when you do find one.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 09-20-2007, 08:57 PM   #3
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I think all trucks build sheets are located in the seat. Some expert will chime in.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 09-20-2007, 08:57 PM   #4
tcb-1
Nothing to see here.....
tcb-1's Avatar
yep, that's the most common place for them. mine had one in the bottom and one in the back. even the GM car line had them stuck in the back seat and sometime the seat bottom as well.
as the vehicle was rolling down the line (most likely at final inspection) the inspector would basically check the sheet and either approve or reject. they would then insert the build sheet in the seat and that was that.
build sheets are always interesting to look at. it will tell you absolutely everything about the car/truck, engine, tranny, options, rear end gears....even if they installed hold down brackets for rail travel.
nice find. take care of those things, 'cause that just may bring you a few extra dollars down the road if you ever sell her.
tcb-1 is offline   Reply With Quote
Old 09-20-2007, 08:59 PM   #5
69GMCor70Chevy
69GMCor70Chevy's Avatar
My Marauder's was in the frame of the back seat so it wasn't just a GM thing.
68 Camaro - 327 Original Red on Red Car
69 GMC LWB - Built 350 a Blast To Drive
69 GMC LWB - "Green Machine" One Family Truck
70 Mercury Marauder - Future Project
69GMCor70Chevy is offline   Reply With Quote
Old 09-20-2007, 09:01 PM   #6
syncrov69
syncrov69's Avatar
Any body a picture of this sheet i'm curious.
syncrov69 is offline   Reply With Quote
Old 09-20-2007, 09:09 PM   #7
tcb-1
tcb-1's Avatar
so true. forgot that a friend found the build sheet of his 70 Mach 1 in the back seat as well.
now that I'm thinking of it, Chrysler/Dodge/Plymouth did the same (I believe?)
Old 09-20-2007, 09:10 PM   #8
jott_06
Camaro Club
jott_06's Avatar
i was just looking at it and i noticed it has an option marked down that i thought was only an option in 67. It is the panoramic rear window. I thought that came standard on 68 and up. Also what is the Custom C&C Equipment?
Old 09-20-2007, 09:13 PM   #9
tcb-1
tcb-1's Avatar
comfort and convience package. just a stab in the dark.
as for the cab, is it an early year 68? may explain the "optional" panoramic rear window?
Old 09-20-2007, 09:24 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it was typed in on many early ones, and yours is a january truck, so it counts as an early one.
Old 09-20-2007, 09:27 PM   #11
CG
BlahBlahBlah
Here is the one out of my 68 3/4 ton 4x4...sorry its so hard to see. These things are pretty delicate.
Old 09-20-2007, 09:36 PM   #12
oldsmobilekindofguy
I found mine when I took my gas tank down form my 1970 olds and it was taked on the top side of the tank. it is in fairly decent shape for riding up there for 36 years
1967 c-10 longbox project, check it out in projects
1969 c-10 parts pickup, twisted frame
Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block
oldsmobilekindofguy is offline   Reply With Quote
Old 09-20-2007, 09:39 PM   #13
jott_06
Camaro Club
jott_06's Avatar
well that sucks. mine ends right before the part that is supposed to have the dealer info on it. something must have ate the bottom two inches of it. Did someone say they put another under the seat or did i read that wrong?
Old 09-20-2007, 09:40 PM   #14
turner15
That is so cool, my seat is out and I'm checking tomorrow!!
turner15 is offline   Reply With Quote
Old 09-20-2007, 10:01 PM   #15
tcb-1
tcb-1's Avatar
nice CG. looks like your rig stayed fairly close to home. my 69 came from the Fremont plant as well. do you have the smog taps on the manifolds. I know they were there for a reason, but can't figure it out. all the California smog devices have long since been pitched for my baby....
Old 09-20-2007, 10:03 PM   #16
David Flores
David Flores's Avatar
I don't even have a seat.
66 c10 swbfs
My Build.
David Flores is offline   Reply With Quote
Old 09-20-2007, 10:34 PM   #17
CG
BlahBlahBlah
All I have of this rig is the frame, vin tag, build sheet and a clear title. Oh and the box, but its hammered....Nice huh?
Old 09-20-2007, 11:00 PM   #18
CrashEd
72 chevy
CrashEd's Avatar
I have a 72 C/20 that my dad bought new that has the build sheet, sales sheet,the plastic packet that the owners manual come in with all the original booklets that come with it, and i have driven it sense it was new. Its all tore apart now trying to get a face lift done on it. Living on a farm all its life was hard on it.
Ed
CrashEd is offline   Reply With Quote
Old 09-20-2007, 11:24 PM   #19
crzngmychvy
"1972 C5"
crzngmychvy's Avatar
That's cool that you found it. I'd check my seat but they are from a 90s suburban.
- 72 2wd Blazer ...sold...
2wd Blazer Page
crzngmychvy is offline   Reply With Quote
Old 09-21-2007, 06:32 AM   #20
72armyswbtruck
72armyswbtruck's Avatar
Yup the first place I check when I am lookin at a vehicle is under the seat or behind the seat. I love finding those darn things.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 09-21-2007, 07:34 AM   #21
tclaremont
Keep in mind that there is no guarantee your truck will have a build sheet. There was no policy that said the build sheet had to stay with the truck.
The build sheet is the "recipe" for the truck as it travels down the assembly line. When the truck got to the last station, many of the sheets wound up on the factory floor, as opposed to in the truck.
On my 1970's Pontiac Grand Ams, they were mostly on the tops of the gas tanks. I have also found them under the carpet, behind the door panels, above the glove box liner, etc. Basically anywhere they could be "hidden".
Also, once you remove the build sheet and it is exposed to daylight, the ink fades pretty fast. Do something to protect it as soon as you can.
tclaremont is offline   Reply With Quote
Old 09-21-2007, 09:04 AM   #22
Bucky71
There were 3 build sheets under my seat. 2 were for my truck and the other wasn't. Weird eh?
Bucky71 is offline   Reply With Quote
Old 09-21-2007, 12:44 PM   #23
michael bustamante
michael bustamante's Avatar
in my old 68 vw bug I found an OLD bag of mary jane. you never know what you`ll find. I wish I had inspected my seat before I got rid of it now. I bet the check sheet for my truck was still there too.
michael bustamante is offline   Reply With Quote
Old 09-21-2007, 02:35 PM   #24
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Sweet find! I won't be as lucky, as the PO put a different seat in my truck...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-21-2007, 02:53 PM   #25
Classic Bowties
Always on the hunt...
I have found build sheets behind the factory carpeted fibre board that covers the gas tank on the A50 optioned bucket seat trucks. I also found one behind the pass. side door panel on my 71 Cheyenne Super K20, tucked in there with it was a factory assembly line change order sheet containing a few last minute changes by the guy that ordered the truck new, it is dated march 3rd of 71 and it has the initials of the original purchaser ok'in the changes. I am glad that extra document was still with the truck after all these years, Cb
Classic Bowties is offline   Reply With Quote
