Old 09-22-2007, 10:22 PM   #1
tenochiturbide
tenochiturbide's Avatar
One side higher~
As you all may know I heve been working on my truck... so here is the problem... I installed a new set of 2 1/2" drop spindles and 2" drop coils!! along with a front sway bar!! and for some reason the drivers side is higher then the other!!! about 3/4" i checked the spring thinkin' it could be out of the pocket but no!!! i moved it around but still no luck!! What could it be???? Thanks !!! I'll try to post some pics tomorrow!!
tenochiturbide is offline   Reply With Quote
Old 09-22-2007, 10:25 PM   #2
Re: One side higher~
What is the shape of you cab mounts.
Probably what you are thinking though if you didn't notice it before you swapped springs. Check the seating on both sides.
Palf70Step is online now   Reply With Quote
Old 09-22-2007, 10:29 PM   #3
tenochiturbide
mmmmm i'll check tomorrow!!! thanks for the idea!!!
Old 09-23-2007, 06:08 AM   #4
dave3156
Also check your radiator support. They rust out on the passengers side under the battery and where they mount to the frame could be so rusty it has dropped down a little in the front. The front of the fender bolts to it so it could make the front passenger side a little lower than the drivers side. Mine had this problem and i fixed it with a new radiator support.
dave3156 is offline   Reply With Quote
Old 09-23-2007, 06:21 AM   #5
earl87gta
earl87gta's Avatar
I would pic a spot on the frame to mesure from if the frame is level then its time to start checking the body.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 09-23-2007, 08:55 AM   #6
tenochiturbide
Thanks for all the help!! I'll spend the day checking all of that options!!!
Old 09-23-2007, 09:34 AM   #7
cdowns
cdowns's Avatar
did you check that the springs were the same height b-4 installing?? i've seen and heard of alot that aren't from suppliers that aren't that conscious of quality control
Old 09-23-2007, 09:36 AM   #8
tenochiturbide
well I put 'em side to side and they seem to be equal~! I call early classic and they told me to swap 'em left to right!! and see what happen!!
Old 09-23-2007, 10:00 AM   #9
Boog
laying low
Boog's Avatar
I seem to remember years ago some factory springs were vehicle side specific. I don't know about these aftermarket springs though. Did the ECE guy talk like this is a common occurence?
As said you need to measure the frame to floor at same points right and left to make sure it is not a body misalignment prob or low tire, etc.
I have also heard of some guys having to send their springs back to be replaced but not sure of which company they came from.
Also worth mentioning is quite often springs will take some time to settle after installation. Drive it some and remeasure.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-23-2007, 10:07 AM   #10
71tahoe
71tahoe's Avatar
Also check your back springs. When we first bagged my son's truck, the before measurements were about 1" higher on the front PS. With bags it was almost perfect. The rear coils were the difference (PO heated them).
71tahoe is offline   Reply With Quote
