Old 09-29-2007, 10:22 PM   #1
project 67 sub
project 67 sub's Avatar
Question ok guys i need some help with a problem on my 67 burb
well i figured that i would ask here because their are more people that traffic this area than the burb area. but anyways here is my problem that i am having. i lowered the back of my burb 2"s with lowering springs and the rearend is not centered, it is off (shifted to the passenger side) and i would like to know what i can do to center it evenly from side to side? it is also causing my tires to rub. what can i buy(and were do i get it) that will solve this side to side alignment problem?
project 67 sub is offline   Reply With Quote
Old 09-29-2007, 10:38 PM   #2
qksilver
Re: ok guys i need some help with a problem on my 67 burb
you need to get an adjustable panard bar, aftermarket. The site vender's can help you out with that
qksilver is offline   Reply With Quote
Old 09-29-2007, 10:59 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
This is a coil spring burb right and not a leaf??
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-29-2007, 11:03 PM   #4
earl87gta
earl87gta's Avatar
http://www.earlyclassic.com/catalog.aspx they call it a Super Track Bar Kits
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 09-30-2007, 01:17 AM   #5
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
As previously mentioned it is in fact caused by your panhard bar. As the bar swings through its arc it will deflect from side to side. Your bar would normally drop as it went from it's mount on the driver side frame to the stock mount where the diff casting meets the passenger axle tube .Since you've lowered the burb, in effect raising the axle in relation to the frame, the bar is now more level in it's arc. this has the effect of pushing the axle to the passenger side.
Since you are a "static" drop, a replacement adjustable panhard would do the trick. On the cheap you could cut the axle end off your panhard bar and drill and tap it for a hiem of suitable size with a jam nut. Ideally replacing your stock rod with a longer one will minimize the arcing effect. In the past I've made my own with the axle mount on the spring perch in effect adding about a foot of length.
If your thinking about going to an adjustable susp. (air,juice) at anytime in the near future my opinion would be to run a watts style link as this will keep the axle centered through the travel.
josh
RunninLo is offline   Reply With Quote
Old 09-30-2007, 08:21 AM   #6
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Question Re: ok guys i need some help with a problem on my 67 burb
any pics of said burb ?
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 09-30-2007, 05:28 PM   #7
project 67 sub
josh
yes i plan on doing a full air ride suspension later on down the road. this watts link your talking about, how well do they work and how much do they cost, and were can i get one that will work with my 12 bolt diff?
i dont have any current pics of the burb, but here are a couple of pics from a couple months ago before i raised it back up for a while(temporarily).
and a photo shop of close to what it will someday look like
Old 09-30-2007, 05:31 PM   #8
project 67 sub
yes, its a coil spring 1/2 ton burb
Old 09-30-2007, 07:08 PM   #9
earl87gta
earl87gta's Avatar
Speed way sells them for the same price as an adj panhard there is just some welding involved its not a direct bolt in like the pannhard bar is.
Earl
Old 09-30-2007, 07:12 PM   #10
earl87gta
earl87gta's Avatar
cheaper then I thought on $69 for the kit http://www.speedwaymotors.com/p/3398...l?itemNo=watts
Earl
Old 09-30-2007, 09:23 PM   #11
project 67 sub
were can i get one that will work with my 12 bolt diff. that would be a bolt in deal, and how much?
Old 09-30-2007, 10:54 PM   #12
dave2953
Dave's not here, man
dave2953's Avatar
I got mine at Early Classic (www.earlyclassic.com) I think they are on sale now for $109, and it's a high quality piece. It will work with your 12 bolt, too.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 09-30-2007, 11:20 PM   #13
RunninLo
RunninLo's Avatar
don't forget about the KP components unit. Nathan @ porterbuilt is a distributor for KP AND a site vendor and Clint (Kontrol Phreaks) is a member here. Nothing like supporting those that support the board. The KP unit is designed to be bolt in for the 67-72 trucks with 10 or 12 bolt ( specify when ordering) and should work with our burbs. I hope to find out very soon and post pics to my build thread.
Old 09-30-2007, 11:28 PM   #14
RunninLo
RunninLo's Avatar
Forgot to mention the KP unit is in final development and pricing isn't yet finalized. One important thing if you build your own kit or buy a universal kit, make sure that your watts is set up so that the bars the come in from the frame to the pivot are level at ride height. To be perfectly honest I'm not sure why but guys way smarter than I told me to do it that way when I built my first one from scratch.
Josh
