Old 09-30-2007, 08:35 PM   #1
dhughins
dhughins's Avatar
what tools for lowering?
i just ordered a 3/5 drop from jcwhitney. its a western chassis with front drop springs and a flip kit in the rear. no c notch. what tools will i need to do this? i still have probably two weeks before it gets here. i hope tires wont rub. right now i have 31.50's on there. will have to do till i can save up some more dough.
any ideas what i can do about that tailpipe hanging there? i have the original i6 in there and dont wanna do anything drastic but it sure looks funky hanging there. i wanna replace the motor on down the road but that will probably be the last thing on my list. the last truck i had i lost interest when i had the motor out so long and ended up selling at a huge lost.
dhughins is offline   Reply With Quote
Old 09-30-2007, 08:57 PM   #2
75shortysocal
350+dual flows= fun :)
75shortysocal's Avatar
Re: what tools for lowering?
tool:
anything you think you might need...you will need
kit:
got a link to the kit you got?
exhaust:
cut it off before the rear axle
ALWAYS CHECK YOURE FRONT WHEEL BEARINGS!!
SPINNING OUT ON THE FREEWAY DUE TO THE BEARING GOING OUT IS PRETTY HAIRY!!!
75shortysocal is offline   Reply With Quote
Old 09-30-2007, 09:05 PM   #3
pcmcobra
pcmcobra's Avatar
standard socket set.
Hammer for "pursuading" ball joints/spindles loose, flathead screwdriver, needlenose pliers.(for cotter pins)
Grinder for taking rivets out in rear.
Balljoint separator, could use that for tie rods also...
I did not have to cut my exhaust....
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 09-30-2007, 09:26 PM   #4
dhughins
dhughins's Avatar
http://www.jcwhitney.com/autoparts/P...Browse/s-10101
try this for a link
Old 10-01-2007, 09:36 AM   #5
beaterC10
You will also need a decent drill motor and a 3/8 drill bit to install the aftermarket bump stops on the rear. A torch may be needed to persuade the rear shackle/spring bolts to move. Those were a pain on both flip kit installs I have done.
You should be okay on the tires. I have 235/70/15 on the front and 31/10.5/15 on the rear of my 3/5 dropped truck.
I had 255/70/15 on the rear, but after the drop, the rear sat lower than the front. The taller tires on the rear fixed that problem.
beaterC10 is offline   Reply With Quote
Old 10-01-2007, 03:37 PM   #6
knightlife
Dark Heart Motorsports
knightlife's Avatar
BFH... (big F'n Hammer)....
works for everything
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 10-01-2007, 07:20 PM   #7
bb1979
bb1979's Avatar
If your only doing springs in the front shouldn't need a ball joint separator just remove the brake caliper, unbolt the shock and remove the upper a arm from the frame (your going to need a wheel alignment anyway), have the truck on jack stands with the trolley jack under the lower a arm. Slowly lower away. I find its the fastest way to change front springs
1979 C20 pickup 454 big block turbo 400, 4.56 gears
bb1979 is offline   Reply With Quote
Old 10-02-2007, 11:31 PM   #8
tyjoja
Nice truck, mine has a I6 too. I don't know if anyone said anything about the bed, It pretty much has to come off, wich is fairly easy, 8 bolts and a guy on each corner. also have to undo the gas tank filler from the body and the wiring plug to the taillights. as for the rivets I couldn't get to all of them with a grinder, what work great for me was a good cold chisel and about a 2-3 pound hammer. good luck
tyjoja is offline   Reply With Quote
Old 10-03-2007, 04:03 PM   #9
dhughins
dhughins's Avatar
u mean i cant leave the bed on?
Old 10-03-2007, 04:08 PM   #10
cochino12
It followed me home?
cochino12's Avatar
You can leave the bed on
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 10-03-2007, 04:18 PM   #11
Malo83
Cruzzzn' Vet
Malo83's Avatar
with just the flip kit your fine, but if you go the C notch then yeah the bed comes off
Malo83 is offline   Reply With Quote
Old 10-03-2007, 04:23 PM   #12
streetstar
streetstar's Avatar
or just get a chunky woman to sit on the hood, and 2 to pose provocatively in the bed --- the height of the truck will come down, and all it will cost is a couple of bags of peanut butter cups ---
and will still be as practical as a lot of airbagged trucks i have seen
streetstar is offline   Reply With Quote
Old 10-03-2007, 08:22 PM   #13
bigblock73
yeller
bigblock73's Avatar
You do not need to remove the upper A-arms to put in coil springs. All you need to do is unbolt the shock from the LCA, disconnect the LCA from the spindle (while supported by a jack), once disconnected, simply lower the LCA (with the jack)...the spindle and LCA will seperate...and the spring can be removed. Install is reverse order of removal.
bigblock73 is offline   Reply With Quote
Old 10-03-2007, 09:15 PM   #14
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Sorry Jeff. I swear I will finish up that article for you.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 10-03-2007, 09:25 PM   #15
bigblock73
yeller
bigblock73's Avatar
Slonaker
I didn't say a word...but was thinking it.
No hurry, I haven't done much site work in a while, been busy myself too.
