Old 10-03-2007, 02:37 PM   #1
Sinister
Between Trucks...
Sinister's Avatar
Windshield wipers...
What are some steps for trouble shooting windshield wipers?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-03-2007, 02:56 PM   #2
cdowns
cdowns's Avatar
Re: Windshield wipers...
well the first step would be to identify what they are doing or aren't doing thats causing concern
Old 10-03-2007, 02:59 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
They don't work at all, and the fuse is good...
Beat it to fit,
Old 10-03-2007, 03:06 PM   #4
cdowns
cdowns's Avatar
first i'd see if there is 12v at the switch with the ign switch in the on position// then id see if theres 12v coming out of the switch when its turned on
Old 10-03-2007, 03:15 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
Thanks, I'll give that a shot. If I have voltage at the switch and coming out of the switch, then the motor is bad?
Beat it to fit,
Old 10-03-2007, 03:52 PM   #6
cdowns
cdowns's Avatar
that would be right if you have a good ground at the motor
Old 10-03-2007, 03:56 PM   #7
Sinister
Between Trucks...
Sinister's Avatar
Cdowns, thanks for the quick replies, I'll try and see what's up with it this weekend...
Beat it to fit,
Old 10-03-2007, 04:53 PM   #8
Putter
More Cowbell....
Putter's Avatar
There is ZERO power coming out of the factory wiper switch. The power is from the fuse panel to the motor (yellow wire).
The switch offers ground only.
Ground the center (Dk Blue) wire for wash.
Ground the black wire for high speed.
Ground both outer wires (Lt Blue & Black) at the same time for low speed
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 10-03-2007, 05:16 PM   #9
Sinister
Between Trucks...
Sinister's Avatar
Somebody should write up a FAQ for this problem...
Beat it to fit,
