Garage Queen Material
things i need to do/get
in order of how i'm gonna do it:
1. get shocks mounts rewelded 1-1.5" over to accomadate flip kit plate. i'll get this done in middle of january when me and my friend take my truck up to his night votech class to fix it, and while i do that, i'm gonna have the bump stops removed then. i would remove them now, but i cant bolt on a shock on the drivers side, because the nut wont fit, so i'm gonna continue to ride on the bump stops until i get that done. 2. get new tires IF my current ones continue to get ate up since i rolled the fender lips today. 3. get drop shocks 4. get new shortie headers |
can you get a pic of the rolled fender lip. i'm interested to see how that turned out.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
#3 | |
![]() i made 2 cuts in the lip, both right before the fender curves, then i just used the same sledge we used for my drop and i hammered it up a lot. i didnt get it quite rolled as much as i think i need to though, so i will do some more tommorow |
#4 | |
Under construction!
Re: things i need to do/get
Is the leaf spring plate really that large? I have a DJM deluxe flip kit and it doesn't make contact with anything but the shock extender bolts. I put the heads facing outwards so it makes very little contact and I didn't trim at all. ![]() Sounds like you have a good plan. I bet it rides rough w/o a C-notch and stock application shock absorbers! ![]()
2001 Silverado bagged on 22's. *Sold* |
#5 | |
Re: Re: things i need to do/get
