Old 10-07-2007, 04:39 PM   #1
62 short step
62 short step's Avatar
Possible bent frame?
Ok guys hopefully I can get some help with this. I have a 61 4x4, had a d44 closed knuckle axle in it and it pulled to the right bad. Checked everything from the brakes dragging and did my own driveway alignment. Didn't help that much. Now for the new. Swapped out the axle for a corp 10 with disc brakes, put new bushings on the springs all new brakes from calipers to rotors, pads and new warn lockouts. It still pulls to the right. I'm not talking a gradual pull, I'm talking let go of wheel and your in the ditch!!! I have also put new wheel bearings while everything was apart. I'm thinking the frame is bent but I can't find a place where it looks bent. Could this be a posibility? Or maybe the axle is not square? I'm getting so frustrated with this thing because it drives like S@@T!!! Any help is appreciated.
62 short step is offline   Reply With Quote
Old 10-07-2007, 08:14 PM   #2
1969k10stepside
Re: Possible bent frame?
Did the body panels all line up on it?Anything look damaged? If you have access,Measure front frame horn drivers side to passenger side rear frame and vise versa and see if the measurements are the same.That would tell you if the frame was bent.
1969k10stepside is offline   Reply With Quote
Old 10-07-2007, 08:41 PM   #3
62 short step
Yea the body panels line up good. I'll have to measure that tomarrow on the frame.
Old 10-07-2007, 09:56 PM   #4
71swb4x4
71swb4x4's Avatar
Have you taken it to an alignment shop?
It always helps to ahve a fresh set of eyes looking things over, especially when they do it for a living.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-07-2007, 11:26 PM   #5
62 short step
No not yet, but I'm scared to drive it!! I'll have to when I find time. Took me two months to do the conversion, might take it another two to get it to an alignment shop!!
Old 10-07-2007, 11:29 PM   #6
62 short step
I have a good 2wd frame, might convert it to a 2wd, tired of messing with all this 4x4 crap!! Don't get me wrong I love the 4x4, but its been a pain in the arse with a 60-66 4x4!!!
Old 10-08-2007, 10:11 AM   #7
eedgell
It's the air up here
eedgell's Avatar
You may want to measure center of rear hub to center front hub or from a common to both sides, place on the frame to the center of front axle to make sure it is square.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 10-08-2007, 04:46 PM   #8
62 short step
Checked the front axle for square, its right on the money. I'm going to try to get it by an alignment shop this week.
