Old 10-08-2007, 01:53 AM   #1
jmking9
jmking9's Avatar
1970 Rear End Question
How do I tell if the rearend in my 70 is the wide or narrow one? I want to convert to 5 lugs but Im not 100% sure what axles i need. Is there A way to I.D. it? Can you get conversion axles for either one? Any help is appreciated.
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 10-08-2007, 07:05 AM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: 1970 Rear End Question
What do you mean by wide or narrow one, There is a difference between 67-72 rear ends and 73 and up rear ends. The 73 and up are longer (the axle half shafts).
On the rear end near the bell housing there should be some numbers, clean off the rear end and get those numbers and someone on here will chime in with the answers that you seek
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 10-08-2007, 07:43 AM   #3
70GMCer
70GMCer's Avatar
In mid 1970 model year, they went to the longer rear. 57 1/2" compared to the older 56".
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-08-2007, 10:36 AM   #4
jmking9
jmking9's Avatar
where do you measure from
1970 SWB Build
Old 10-08-2007, 10:40 AM   #5
67_C-30
I have a radical idea!
67_C-30's Avatar
Backing plate to backing plate.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 10-15-2007, 07:42 PM   #6
jmking9
jmking9's Avatar
The only numbers I could find were on each side of the pumkin on the front of the axle. On the Drivers side it has "GM53" and on the passenger side "NF389683" are these th right ones to ID it. I measured it and I think its 57.5'' backing plate to backing plate. Are these the correct numbers, and if so, Can anyone ID it? Thanks
1970 SWB Build
Old 10-15-2007, 08:30 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
I believe you should be able to use stock '71-'72 axles in your '70 housing since it's the wider version.
Keith
Convert to disc brakes.
