Old 10-09-2007, 03:34 PM   #1
55chevytrk
what frame is it S10-C10
i bought a 55 chevy on a 84 blazer frame.
is this the C10, K10, K5, or S10 frame.
my guess is C10 cause the S10 whoud be way small. what do you think?
Whats the difference between C10, K10 or K5??
55chevytrk is offline   Reply With Quote
Old 10-09-2007, 05:46 PM   #2
Zoomad75
K5Camper
Zoomad75's Avatar
Re: what frame is it S10-C10
If it was a Blazer fram I'd bet money it was a full size K5 frame. S10's were much smaller and had a IFS front axle.
C10's are 2wd half ton trucks
K10's are 4wd half ton trucks
K5's are 4wd half ton SUV's (same as K10, but shorter wb and different rear frame kick up.
Lets see this 55!
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 10-09-2007, 07:35 PM   #3
Pyrotechnic
Pyrotechnic's Avatar
You mean 55 Bel Air, or a 55 truck ?
Pyrotechnic is offline   Reply With Quote
Old 10-10-2007, 08:45 AM   #4
55chevytrk
thanks, good info, it's a truck
Old 10-10-2007, 03:23 PM   #5
kevinr1970
If it is truly an '84 Blazer than:
Is it a 2wd - then its probably an S10 frame as '82 was the last year of 2wd K5's
Is it a 4x4 - if so does it have a straight axle or IFS? If straight then probably a K5, if IFS then defineatly an S10
If is a different year year than '84 all bets are off.
C's are always 2wd and K's are always 4x4 EXCEPT for K5's (Blazers only) which as noted above were only available as an optional 2wd until '82.
A guy I work with put a late 40's Studebaker truck on to an S10 chasis that had been converted over to a TPI V8 with little modification so don't discount the S10 frame just yet!
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 10-10-2007, 06:24 PM   #6
55chevytrk
thanks,
all i know is that when i bought it the guy put brake pads and bearing on the front. the only thing that fit was a blazer 84. if i check parts the regular listed blazer has one part number and the s10 blazer has another number. so i guess i can find out this way if it is a s10 or not. but then the question is just which year it is. i guess by checking part numbers and can find at least a year range that it can be. this way i can order lowering spindles and leaf springs and not have to return them and hate life.
Old 10-11-2007, 08:26 AM   #7
longhorn71
longhorn71's Avatar
if it has the car bolt pattern wheels it is s-10.they also have a welded in front cross member.boxed front section of frame(factory)
if it has truck bolt pattern wheel it 2wd blazer(5 lug)but last year for a factory 2wd full size blazer was 82 but some could have changed a 4x4 frame to 2wd.they front cross member bolts in on these ones.open channel frame(factory)
if it is a 4wd.
k5 blazer(87 up were v-10s for the model instead of k5)if it has 6 bolt wheel pattern and solid front axle it is full size.open channel frame(factory)
s-10 had IFS in the front.the front cross member in the frame for the front suspension is welded in as well.boxed front frame(factory)
longhorn71 is offline   Reply With Quote
