Old 12-31-2002, 06:18 PM   #1
Big Paul
Iamnotanofficerofthelaw
Big Paul's Avatar
Question Help out a friend/Tank switch problem.
My friend just bought a '80 4x4 and he's got a problem with his tank switch.
He can't get one of them to work so he can only use the right side I believe.
I know some of you guys have had this problem. What can he do to fix it?
~Paul~
'96 C1500 Silverado- Vortec 5.0L/Exhaust/Stock
'87 S-10 Ext Cab- 2.8L/700r4
KIA Caught fire 12/7/03
Big Paul is offline   Reply With Quote
Old 12-31-2002, 07:16 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
Paul, it's one of two things. The dash switch, or the switching valve. Mine messed up on me and wouldn't switch right. Sometimes it would, others it wouldn't. I bought a new dash switch for it. Didn't help. Bought a new switcher valve, problem solved. If I were a betting man, I would bet on the valve. Of course, before someone says something, it could also be as simple as some bad wiring.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 12-31-2002, 07:32 PM   #3
Big Paul
Big Paul's Avatar
How much does this valve cost? And is it pretty simple to install?
~Paul~
Old 12-31-2002, 07:43 PM   #4
swervin ervin
I bought both at my local Chevy dealer. The dash switch was around $8 bucks. The selector valve was $75 bucks. Now, I know that they list these in the J.C. Whitney catalog for less. But, if I understand what everyone says, they don't fit right. Personally, I can't stand things that don't fit right and need to be rigged to get them to work.
Mike
Old 12-31-2002, 07:44 PM   #5
swervin ervin
Oh, sorry, the install is not too bad. It really helps if you have small hands.
Old 12-31-2002, 10:01 PM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I paid $68 for A/C delco replacement. Having small hands sure does help when replacing the valve. It's a good idea that if anyone ever takes the bed off the truck, replace the valve.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 01-01-2003, 02:15 AM   #7
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Paul if you can give me more info on his problem I can diagnose it for you. If he has fuel only but has reads on both sides his wiring may be messed up. If he has one wire (green) going to it tell hi to switch the power to the left side on the switch and take a test light to the green wire. If it does light up then bad valve if not then either bad wiring or bad switch.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 01-01-2003, 03:07 AM   #8
Big Paul
Big Paul's Avatar
All I know is when you switch it to the left tank the gauge goes all the way past "F" and sits at about 5 o'clock on the gauge.
The right hand tank reads correctly. But my friend tells me the other day that now it will only stay at "F".
Maybe it is just the wiring thats wrong.
~Paul~
Old 01-01-2003, 04:58 AM   #9
79BIG10
79BIG10's Avatar
Tell him to change the swtich out. He'll need to get the ashtray out to get to it better. It should be like mine was and it has 2 speed nuts on back (make their own threads) just take them off then the cover and the switch will come out. On the gauge I would also have him check his grounds on the tanks. But with both acting funny I would tell him to change the switch to see if it helps.
Old 01-01-2003, 12:51 PM   #10
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
I'm going through these troubles on my 84 right now, and have before too.
Based on what you said here, it is the selector valve (under the right front corner of the bed) that is bad. It is not moving all the way when your buddy selects the left tank. There is only one moving part in the valve and it ports the 3/8" fuel line, the 1/4" return line and makes the contacts for the fuel gage. By not moving all the way, it makes the fuel gage see an open circuit causing it to go past full and stay there. Also the ports aren't lined up to take fuel from the left tank so it will quickly run out of gas. The fact that it moves somewhat means the dash switch is doing its job.
On a separate note, my 84 switches just fine, but about 2 minutes later the truck dies on the left tank. I would say I just have a bad tank of gas, but as it starts sputtering if I switch it back to the right, it immediately clears. If I had bad gas, I would expect it to take a minute for the bad gas to run out. I'm wondering if my gas cap went bad so it's drawing a vacuum on the tank or something. Anyone heard of this one?
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 01-01-2003, 05:35 PM   #11
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
This condition can be caused by a poor or missing ground you say he just got the truck so maybe the previous owner had the tank out and damaged the tank wireing or failed to reconnect the ground wire.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
