Old 10-13-2007, 12:25 PM   #1
Luvlegs
Luvlegs's Avatar
sport bump brackets wrong? UGH! Any help?
Just put on the brackets - first pic is how they are straight across - the two inner ones are closer to the truck
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 10-13-2007, 12:26 PM   #2
Luvlegs
Luvlegs's Avatar
Re: sport bump brackets wrong? UGH! Any help?
The inner ones will not flip over as the bent out part clears the bed bolt
and the holes do not line up to any other set of holes.
1972 C10 L6 3OTT
Old 10-13-2007, 12:29 PM   #3
Luvlegs
Luvlegs's Avatar
Lastly, you can see how the ends that should be "verticle" are angled the wrong way so they will not be plumb with a perfectly verticle bumper (which is the way my new one is)
I cannot flip the inners over and switch sides as the bent up piece (to clear the bed bolt in the previous pic) will hit the bottom of the frame rail before the bolt holes can line up.
Any suggestions? Thanks all.
1972 C10 L6 3OTT
Old 10-14-2007, 04:00 PM   #4
Luvlegs
Luvlegs's Avatar
Ttt
1972 C10 L6 3OTT
Old 10-14-2007, 04:29 PM   #5
Andy4639
Old member
Andy4639's Avatar
You can't lay the brackets against the bottom lip of the frame and redrill the holes in the frame to line up? That's what I would suggest doing.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-14-2007, 04:38 PM   #6
Luvlegs
Luvlegs's Avatar
I was thinking that all the holes are there, so there has to be a way they are supposed to work - thought about drilling but that's the last resort (short of welding) - Does everyone that puts on a sports bumper have to drill their frames??? And still - look at the angle of the inner brackets - they angle the wrong way... somethings not right, but what?
1972 C10 L6 3OTT
Old 10-14-2007, 04:51 PM   #7
powell72
powell72's Avatar
Is it possible you have the outer brackets on wrong? Maybe turned around? How much movement is there on the inners when the bolts are loose?
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 10-14-2007, 05:24 PM   #8
uncle
This may or may not help. Do the outer brackets have a small hole on the top side for the pan to bolt to?
uncle is offline   Reply With Quote
Old 10-14-2007, 07:18 PM   #9
Luvlegs
Luvlegs's Avatar
I believe I have them on exactly as they are in Uncles pics..... but, I'm going out to look right now and make sure..... Thanks so far guys - back in a minute.....
1972 C10 L6 3OTT
Old 10-14-2007, 07:30 PM   #10
Luvlegs
Luvlegs's Avatar
ok - rivet holes are up - is it possible the outter bracket bolts through the funky shaped hole made by the inner bracket and the frame (up to the right a bit in the 2nd pic)?
Then, it still doesn't solve the incorrect angle of the brackets (pitched down) - sorry gang but I'm just not getting this for some reason....
1972 C10 L6 3OTT
Old 10-14-2007, 07:33 PM   #11
Luvlegs
Luvlegs's Avatar
one more pic
1972 C10 L6 3OTT
Old 10-14-2007, 07:49 PM   #12
67_C-30
I have a radical idea!
67_C-30's Avatar
Its dark outside, and I was just (literally) stabbing in the dark, but this is placement on my truck. The Reciever hitch kinda gets in the way. I'll get more tomorrow if you still ned them. Mine do seem like they pitch downhill though. Have you tried test fitting bumper up there?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 10-14-2007, 08:28 PM   #13
Luvlegs
Luvlegs's Avatar
I haven't tried to fit it yet - the inners are about 3" closer to the truck than the outters so it seems like a mute point at the moment. Thanks for taking those - between your and uncles, I feel I'm on the right track but..... I wonder if I received a set of front brackets instead of rear outters? - they do look like the rear outters....... then again, my outters have the rivet holes in them....
1972 C10 L6 3OTT
Old 10-14-2007, 08:36 PM   #14
67_C-30
67_C-30's Avatar
I thing I noticed different in your pocs vs mine is that my inner bumper bracket has 2 bolts near the end and you have only 1. Do you not both in, or is it possible not in the right place?
My trucks
Old 10-14-2007, 08:46 PM   #15
Luvlegs
Luvlegs's Avatar
I see what you have there... I do have another hole in the bracket but there are no two holes that would line up for me to put in two bolts... If you look at the very last pic I posted, you can see there are no other holes that would line up - and two pic before that, you can see the holes in the inner bracket are not near any other holes. I appreciate your time with this...
1972 C10 L6 3OTT
Old 10-14-2007, 08:48 PM   #16
67_C-30
67_C-30's Avatar
I went out and got some more, and I believe they are the wrong bracket. Your outers look a little different than mine. My may be different because of the auxiliary springs, but I'm not sure.
My trucks
Old 10-14-2007, 08:53 PM   #17
Luvlegs
Luvlegs's Avatar
Those first two pics of yours look like they've been cut down - almost like (God forbid) if you hit something, that bracket will just bend over - the last one looks like the two of mine though. Gotta call it quits for the night, bedtime early to rise and all that other stuff - work is seriously cutting into my personal and social life.... thanks for your time man and don't go back out tonight - I'll start this up again in the morning..
1972 C10 L6 3OTT
Old 10-14-2007, 10:20 PM   #18
powell72
powell72's Avatar
Hold the bumper up and see if the holes in the bumper line up with the brackets, I think you have the brackets switched, left to right. The end you have bolted to the frame is bolted to the bumper on my truck.
Chris
Old 10-14-2007, 10:38 PM   #19
67_C-30
67_C-30's Avatar
I believe you might be right Chris. The hole that bolts to the topside of the bumper looks too close to the truck in the pic below.
My trucks
Old 10-15-2007, 07:06 AM   #20
Luvlegs
Luvlegs's Avatar
NOW I SEE IT! Geesch - must've had a brain bubble - I'm pretty sure I flipped 'em end for end but that hole is indeed in the wrong spot. I did measure the distance from each hole and they do line up with my new bumper. I'll give it a shot tonight and see what happens - THANKS GUYS!
1972 C10 L6 3OTT
Old 10-15-2007, 10:02 AM   #21
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If that doesn't do it, try bolting the brackets to the bumper, then mount the bumper to the frame.
Member Nr. 2770
Old 10-15-2007, 10:10 AM   #22
67ChevyRedneck
67ChevyRedneck's Avatar
These are the correct holes from the outside of the frame.
The angles may look goofy, but put the bumper on, that's how they're supposed to be.
You are correct, the inner ones are notched to clear the bed bolts. Your set up looks correct to me, except you have the wrong part of the outer bracket bolted to the frame. That end gets bolted to the bumper.
Which means I think you'll need to reverse them, and then switch sides. The downward angle needs to match the angle of the inner bracket, that should still keep the bolt hole at the top for the rock guard.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-15-2007, 12:20 PM   #23
Luvlegs
Luvlegs's Avatar
yep - I think that is it - I swear I tried flipping/switching the outters... but I will again for sure.... that one is definately on incorrectly as pointed out, the rivet hole is under the bed.
1972 C10 L6 3OTT
Old 10-15-2007, 10:48 PM   #24
67_C-30
67_C-30's Avatar
So did you get it straightened out?
My trucks
Old 10-16-2007, 09:30 AM   #25
Luvlegs
Luvlegs's Avatar
Didn't get out to the truck until after 10 last night and that was enough for me - no lights so I had to do it by flashlight- YOU GUYS GOT IT, I turned them over and flipped end for end and sure enough, the best I could tell in the dark, that should do it! THANK YOU guys!
Should have pics in another day or two (have to get bolts for the bumper yet)
1972 C10 L6 3OTT
