The Original HotRod KnifeMaker
![]() Join Date: Jan 2007
Painless Wiring Vets- Couple Questions ??
Sat down with my just-delivered new 18 circuit Painless wiring harness this morning.
My truck is a 69 GMC 1/2 ton 2WD. I have been reading every post here that showed up under a search for wiring. Most say to just follow the instruction EXACTLY and it will be simple. Um-Hm. The harness is broken down into four sections as I expected: Dash Engine Rear Extra door stuff The first thing I notice is that all the wires are bundled for the first 18 inches. This is obviously meant to stay in place. 1. Is this made so that the dash stuff goes out into the engine well and then back into the cab somehow? Or should I just cut open the factory bundling so I can run the dash wiring up into the dash area inside the cab? 2. The instructions say to route the rear wiring down onto the 'floor pan'. Can't do that without cutting and redoing the factory bundle ties. I was told that our trucks have the rear wiring out into the engine well and then down the firewall and into the frame for the trip to the rear. So should I just redo the bundle to that the wiring can go the correct direction from the fuse block or am I way too slow to do this myself? Thanks for your input-
Dave 69 GMC SWB 2WD 454 Turbo 400 Last edited by WinDancer; 10-14-2007 at 01:35 PM. |
Re: Painless Wiring Vets- Couple Questions ??
I just heard from another member- won't post his ID since he PMd me:
************************ howdy... im sitting here at the exact same juncture as you... i have the kit all spralled out (mostly sitting on my hood), but i just cant think of the best place to start... so ive not. ************************ Can someone help get us started? I decided to undo the first 18" section of the bundle and found that two of the sections have common wires NOT starting or stopping in the fuse block... And how are you supposed to get those big fat bundles through the 1.25" hole that Painless says to drill? Thanks,
Dave 69 GMC SWB 2WD 454 Turbo 400 |
#3 | |||
It's been awhile since I did mine so I'll try to help out the best my memory will let me. I don't know if it will make a difference, but did you order the kit made specifically for our trucks, or did you buy a universal kit? IIRC all the wires were bundled conveniently so I didn't have to mess with them much.
![]() Quote:
Hope this helps.
72 C10 lwb fleetside -stock 350/350 combo Last edited by 68 P.O.S.; 10-14-2007 at 07:36 PM. |
Junior Member
btw, twas i that sent the OP the message.
i went ahead and took the plung... count my truck with "the ones that no longer are able to start". i ran into some surprises, most notably that the PO didnt properly redo the steering column connector... ![]() i dont know the first thing about electrical stuff, but i guess im about to learn first hand! btw, if i want to make the steering column connection right... where should i start? im really hoping that that portion can be purchased seperate from "an entire steering column". Last edited by RedZ71; 10-14-2007 at 08:10 PM. |
Iam almost finished with my painless wiring kit part number 10206. You can pm with your phone number all see if I can help you.
I found a good write-up in one of the mags...
Link is below if you'd like yo have a look-see
Junior Member
despirately looking for said link!!! lol
Here is the link..........
http://www.customclassictrucks.com/t...all/index.html
