10-14-2007, 04:08 PM | #1 |
Lower Rad Hose
I ordered a new goodyear lower radiator hose for my 87 1/2 ton 4wd. The new hose does not have a spring in it. I tried to install a spring and it seems nearly impossible to get the spring installed. Autozone did not have a hose with a spring in it either.
Any ideas or manufactures to pick one up? Thanks guys Nick |
10-14-2007, 04:52 PM | #2 |
Re: Lower Rad Hose
Some of the newer hoses are pre-bent, and do not require springs to keep them open, I have yet to have a prebent one collapse on me
All the newer car are all prebent, the older trucks used to have a spring as a safety thing I guess My 86K10, with a 350 has the pre-bent one.....i pulled to original one out, it had a spring. It's been going strong for 2 years now Duro
-1986 K10 LWB, 350 HD,TH400 3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires All original, second owner truck -1979 Monte Carlo, 350, 200r4, 3.73 posi -1987 GT T-top Mustang - slow moving project |
10-14-2007, 04:53 PM | #3 |
Re: Lower Rad Hose
Well the new hose does have some crazy bends in it. Its pretty beefy, just didnt want it to collapse on me.
10-14-2007, 04:57 PM | #4 |
The One And Only !!!
Re: Lower Rad Hose
When I was in the auto biz I installed many springs by spraying armor-all on the inside. Screw the spring in place, When you get to the point the spring is flush grab it with needle nose pliers and screw it in the rest of the way.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
10-14-2007, 05:26 PM | #5 |
Re: Lower Rad Hose
I tried screwing it in but w/ no lube. I'll give it another shot.
Thanks guys. Nick |
10-14-2007, 09:57 PM | #6 |
Robert Olson Transport
Re: Lower Rad Hose
you can try to lube it up and screw it in but you dont need it the pre-bent ones will be fine without the spring ive had one in the truck for years
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
10-16-2007, 11:25 PM | #7 |
Re: Lower Rad Hose
I've seen several springless pre-bent lower hoses collapse after they're a few months old. Last time I bought a lower hose it didn't have a spring in it, so I just used the old spring. When the old spring finally bites the dust, I'm hoping somebody like McMaster-Carr will have something I can use, maybe in stainless.
