Getting window regulator on the track
Any tips on how to get my driver's window regulator back on it's track?
Thanks |
![]() Join Date: May 2005
Re: Getting window regulator on the track
I've found that if you crank the regulator up to the top of the door, slide the rear roller into the rear of the window channel, then pop the front roller into the opening in the window channel.
Of course the roller that goes into the door channel has to be installed first, and leave the four screws holding the regulator to the door a bit loose. All this really should be done with the vent window removed so you can slide the glass back and forth. Hope this helps. Pete |
