10-16-2007, 04:18 PM | #1 |
Alright Alright Alright
need help with brake caliper studs
yesterday i changed out the disk pads on my brakes. when i tried to put the caliper back, the studs went in about 3/4 of the way and then stopped. i compressed the caliper pison all the way aswell as the fittings that the studs go though. this is happening on both studs. what is causing this?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
10-16-2007, 04:22 PM | #2 |
I'M TRUCK CRAZY!
Re: need help with brake caliper studs
Try changing the 2 studs around. (you probably already tryed that)
Put them in the opposite hole and see what happens. You may need to use a tap to clean up the threads Last edited by LOW DOUGH; 10-16-2007 at 04:23 PM. |
10-16-2007, 07:46 PM | #3 |
yea, i did switch them out. i also forgot to add that i also changes my wheelbearings as well. would that make any difference?
10-16-2007, 09:55 PM | #4 |
If you can get the pads over the rotor and the caliper on the spindle then the bearings shouldn't make a difference.
Pads swapped? Do both pads have holes for the bolt? Is one hole bigger than the other? I don't have anything to look at so do you have a picture of what you are describing? |
10-16-2007, 10:31 PM | #5 |
i dont have a camera on me at the moment. yes, the pads have the same size holes and are identical to the old pads. i can see that the studs go straight through the caliper and pads, and and goes half way into the other side of the caliper with out threading it in. like i said, it can thread in about 3/4 of the way in and then it stops (its tough to get it past that and i dont want to strip anything). i cant see any obstructions.
