Old 10-17-2007, 05:29 AM   #1
60ratrod
yes, i do
60ratrod's Avatar
engine progress
so since many of you know i had crank bearings going out in my motor i did a rebuild on the lower end. i also replaced the crank, cam, timing chain and gears also with a high volume oil pump. when i pulled all of the covers and oil pan off i found that my timing chain had a lot of slack in it, so much that it actually ate a groove in the timing cover. so i've gotten all the covers and oil pan painted up along with the intake. i haven't gotten the motor quite put all the way back together but that will be done this weekend. here's the photos that i have so far so enjoy!
60ratrod is offline   Reply With Quote
Old 10-17-2007, 05:31 AM   #2
60ratrod
yes, i do
60ratrod's Avatar
Re: engine progress
more photos of the painting
Old 10-17-2007, 06:48 AM   #3
Lemondrop63
Lemondrop63's Avatar
Re: engine progress
Thats purty! looks good..Cincinnati Bengal colors!
This one time at bandcamp, in my c10, I ran over the girl hiding the flute!
http://67-72chevytrucks.com/vboard/s...d.php?t=255141
Lemondrop63 is offline   Reply With Quote
Old 10-17-2007, 08:14 AM   #4
Stepside65
Still Truckless!
Stepside65's Avatar
Re: engine progress
You definitely outdid yourself. Great job on the paint. Can't wait to see what it'll look like fully assembled in your truck.
~James
Truckless
2009 Hyundai Sonata<~~Wife's sedanomatic
1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive
Founder of The 60-66 Club
Tutor Et Ultor
Stepside65 is offline   Reply With Quote
Old 10-17-2007, 09:22 AM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: engine progress
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 10-17-2007, 10:07 AM   #6
BigDaddyDave
RIP BigDaddyDave ~7-23-09~ You will be missed~
BigDaddyDave's Avatar
Re: engine progress
Hey when you finish yours,stop by my house and paint mine.HAHAHA That looks Awsome.
BigDaddyDave is offline   Reply With Quote
Old 10-17-2007, 06:46 PM   #7
Iron-Butt
454 club
Iron-Butt's Avatar
Re: engine progress
good work
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 10-17-2007, 08:25 PM   #8
04Xrider
Registered thread killer
04Xrider's Avatar
Re: engine progress
Looking good! Doesn't look like you are applying the paint sparingly.
!966 stepside, 350 SB, ZZ-4 roller, Crane roller rockers, 0.030 flat tops, airgap intake, 750 Holley, stainless steel headers, edelbrock SDT mufflers, Mark 8 elec fan, 700R-4, column shift
04Xrider is offline   Reply With Quote
Old 10-18-2007, 12:08 AM   #9
60ratrod
yes, i do
60ratrod's Avatar
Re: engine progress
the engine has 5-6 coats, the intake also has like 5 coats, the pulleys, covers, and oil pan have about 3-4 coats including clear coat due to the black paint hazing over on me
Old 10-18-2007, 03:55 AM   #10
Ham-er
Re: engine progress
Someone once suggested to me that timing chains strech. Perhaps they do a tiny bit but what causes that much slack is that the fiber teeth that used to be on the cam gear have broken off of the metal part of the gear and fallen down into the oil pan. so be sure to check your oil pump pickup tube for bits of the fiber teeth if you are reusing that part. I have seen this many many times. supposedly the factory put the fiber teeth on for less noise. The replacement gears dont have the fiber teeth!
Ham-er is offline   Reply With Quote
Old 10-18-2007, 04:19 AM   #11
60ratrod
yes, i do
60ratrod's Avatar
Re: engine progress
well a new high volume oil pump is on the list of new parts that i am installing on the motor. it probably wasn't the factory gears and chain. but the chain had stretched so much that it ate a groove into the side of the timing chain cover. the only fiber teeth that i have seen was on a ford 400 that i had used for parts when i rebuilt a 351m to a 410 stroker.
Old 10-21-2007, 12:36 AM   #12
60ratrod
yes, i do
60ratrod's Avatar
Re: engine progress
well the motor is put back together for the most part and it looks so perdy!! too bad i forgot my damn camera
Old 10-21-2007, 01:20 AM   #13
Stepside65
Still Truckless!
Stepside65's Avatar
Re: engine progress
Glad you got it all back together.
~James
Truckless
Tutor Et Ultor
Old 10-21-2007, 07:40 AM   #14
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: engine progress
Looks great 60
What carb are you going to use
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
