Old 10-19-2007, 11:31 PM   #1
drivethechevy
drivethechevy's Avatar
front suspension swap?
im looking to swap the front drums on my 69 chevy fleetside for disk brakes without spending a lot of money and one of my dads old mechanic friends told me that the front suspension from 73-late 80's chevy pickups with front disk brakes swaps right in, and he couldnt remeber if i would have to drill any new holes or anything
so what im wondering is if it works? and how exactly i am to go about the swap?
any other cheap ways to get disks on my truck would help me
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 10-20-2007, 06:34 AM   #2
70GMCer
70GMCer's Avatar
Re: front suspension swap?
Yep....direct swap except for 2 holes that do not match up on the crossmember. Most don't even bother with them. What I'm going to do, is swap out all the suspension and use my existing crossmember. Still, everything bolts up.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-20-2007, 07:01 AM   #3
Boog
laying low
Boog's Avatar
Right. I have an 82 front under mine. The 73 up control arms use rubber bushings instead of the metal cups like the earlier ones. Should help isolate some bump and noise. Also know that you need to move the brake lines going to the front wheels as the rubber line attaches in a different location, no big deal to move. And you will need to use a newer master cylinder for disc brakes. This is about the cheapest way to get your 5 lug disc brake front end I know of.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-20-2007, 09:29 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Here's a thread that might help.....
http://67-72chevytrucks.com/vboard/s...nt+crossmember
LockDoc
Leon
Old 10-21-2007, 01:41 AM   #5
drivethechevy
thanks much now i have another question that is similar
does the swap work the smae way if the donor truck is a 90's chevy, cause if so then that will make it much easier cause we have a 96 chevy 1/2 ton tthat we used on our farm till the engine died and i know that has front disks and it would sure save me the trouble of finding another truck to scavenge off the parts i need,
so is there anything else i would have to do to fit that 96 front suspension on my 69 frame?
thanks again
Old 10-22-2007, 01:37 AM   #6
Scott68-93-97
Scott68-93-97's Avatar
Completely different the 96 has the crossmember welded in and the suspension is completely different, trucks up to 88 will work for your donor parts really you can buy all the parts new anyway you dont need a donor its just cheaper, but you could cut the frame off the 96 and weld it to the 69 or mount the 69 cab to the 96 frame the motor will swap into the 96 frame no problem since it had a small block and if the trannys good run the one out of the 96. What went wrong with the motor in the 96 if its a lower end problem you can run the vortec heads on your 350 and all the fuel injection to make a pretty strong good mpg motor. Just swap your sheetmetal and block over to the 96 it would be a pretty sweet swap, good drivability of newer chassis with the classic look
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 11-03-2007, 09:23 PM   #7
drivethechevy
the 96's engine just has a lot of miles on it as far as i know and no one can remember why it stoped running but i pulled the engine apart a few days ago cause i tried getting it started again and it didnt work so i guess i just have everything looked over before i try to use any of it.
would it be easier to swap everything out of another truck crossmember and all or would it be easier to just swap everything accept the cross member? i got a donor truck with the brakes to put on mine so no im looking for the easyiest way to go about the swap,
also id like to upgrade the rotors and all that stuff for the brakes any sudgestion of brands that are great and are affordable?
and would the rear end off a a 73-87 swap in without any troubles?
Old 11-03-2007, 09:28 PM   #8
davidh
davidh's Avatar
I saw a guy here in town, put the rear end from a 80's C10 and changed it over to leaf springs even!!!!!
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing.
davidh is offline   Reply With Quote
Old 11-03-2007, 09:28 PM   #9
davidh
davidh's Avatar
on a 67' that is.
Old 02-13-2008, 08:57 AM   #10
gunnersm8
hey i got a question. and i did a basic search and its likely a stupid question, but i got a chance to grab a 74 g20 van, im thinking i can get the steering column as well as the front end. is this the same thing?
gunnersm8 is offline   Reply With Quote
Old 02-13-2008, 09:39 AM   #11
EyeH8the24
EyeH8the24's Avatar
just finished swapping a 87 front crossmember in my 69,super easy swap.hardest part has been brake lines.but even that isnt too hard to deal with
EyeH8the24 is offline   Reply With Quote
Old 02-13-2008, 10:09 AM   #12
gunnersm8
you used a vn? i presume theyre the samme but wanted to bounce it off you guys
Old 02-13-2008, 10:19 AM   #13
EyeH8the24
EyeH8the24's Avatar
i used a truck..dunno bout a van x member
Old 02-13-2008, 11:17 AM   #14
chrislehr
Engine n00b
chrislehr's Avatar
disk brakes? 5.25 or 3.5"?
chrislehr is offline   Reply With Quote
Old 02-13-2008, 03:59 PM   #15
franky69c10
chevy runs deep
franky69c10's Avatar
just how hard was the brake lines 2 swap, the setup im getting is off a 87 also..
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 02-14-2008, 09:19 AM   #16
EyeH8the24
EyeH8the24's Avatar
i used all the brake lines from the 87,had to make the rear line fit ,napa cut and put a double flare fitting on it for me ...
Old 02-14-2008, 09:30 AM   #17
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
can't use the van stuff, not as wide.
Old 02-14-2008, 09:39 AM   #18
rstewart09
rstewart09's Avatar
I believe the van cross member is wider, at least it was on an 89 van that I got for the motor and trans for my 67 GM
The start of a new toy
1967 GMC 3/4 ton
rstewart09 is offline   Reply With Quote
