Old 10-21-2007, 06:31 PM   #1
bdas70chevy
bdas70chevy's Avatar
need some advice 4 the blazer
i am getting a doner 98 2wheel truck with a new crate motor and tran, 2 put in my 70 blazer my question is what problems am i going to run into. i heard the elec. is a big one, would it b better i keep the 350 tran i have and just run the vortec? is there a company to rework the wiring harness? any help would b good thanx
bdas70chevy is offline   Reply With Quote
Old 10-22-2007, 07:46 AM   #2
vtblazer
vtblazer's Avatar
Re: need some advice 4 the blazer
Stand alone transmission computers are available now, pricey but available.
What tranny does it have?
1/2 ton or 3/4 ton donor truck?
If it we me, I'd keep the over-drive tranny and do whatever it takes to make it work.
vtblazer is offline   Reply With Quote
Old 10-23-2007, 12:34 AM   #3
bdas70chevy
the donor is a 1/2 ton 2 wheel with a 700 r
i was trying to use a lt1 but didnt have all the parts needed. with that i found out that i could have the wiring reworked so i didnt need all the emmisions? havent found out if that is possible on the 98 vortec? and what transfer to use? the married 205 will not work? were do i go for more info?
Old 10-25-2007, 10:43 PM   #4
ABLAZN
Oh..never mind....
ABLAZN's Avatar
bdas70chevy,
If your trans is original, it should be a 4L60-E. It is basically a computer controlled version of the 700R4. You will need to remove the tail section and replace the output shaft with one from Advanced Adapters that will work with your 205 transfer case. Also, you will need a high pressure inline fuel pump and a return fuel line installed. Your stock computer will need to be reprogrammed to get rid of the code that you will not be using for emissions and anti theft modes.
I am thinking of the doing the a similar swap using a complete rolling chassis from a 1999 Tahoe. I have found a place called BTB Products the does a lot of these swaps and has most of the parts and services to help you out. Also , Howell Engine Development has a lot what you need, but I have yet to talk to them and see how complete their services are.
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
MORE TO COME !!!!!! Now going to 2WD!!!!!
Sold.
I got it back after 22 years and did not even know it !!!
THE STORY HERE
Project Low Down Dirty Rat
ABLAZN is offline   Reply With Quote
Old 10-26-2007, 08:14 PM   #5
bdas70chevy
thanx for the info i will check on the web. will i b able to us the donors trans mount? and gas tank? Also the throttle cable is going to b fun? i havent picked up the truck yet going sunday!!!
Old 11-01-2007, 09:34 PM   #6
bdas70chevy
sweet
Old 11-01-2007, 11:07 PM   #7
ABLAZN
Oh..never mind....
ABLAZN's Avatar
sweet
Well what did you find out? I called Howell yesterday, and they seemed pretty knowledgeable about what I needed. Also, I called Advanced Adapter and found the rest of the parts that Howell did not have. I plan on getting the harness and computer from Howell and most likely the inline fuel pump as well. The output shaft and VSS/ tail shaft adapter will come from Advanced. The only other issue that I need to address is the return line into the gas tank. Otherwise, this should be a reasonable swap and much more drivable then the big block that I have now.
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
Sold.
THE STORY HERE
Old 11-03-2007, 07:00 PM   #8
bdas70chevy
i havent found that much? i will get the adapter form them also. what about the shifter? i am going form the stock 350 3 speed to a 3 speed with a overdrive? i thought if it will work us the coulm and shifter for the donor truck. What was the price of the adapter for the tranny? what about the trans bracket? i need to jump into it but having a hard time finding time,
Old 11-04-2007, 01:52 PM   #9
ABLAZN
Oh..never mind....
ABLAZN's Avatar
You have couple of options for shifters. I think that Lokar makes a bracket that will work with you stock column shifter and the cable of the 4L60-E. The other option is going with a floor mounted shifter. I personally would not mess with the steering column from the donor rig, the wiring hassle alone would keep me from doing it. The trans adapter needed are a output shaft ($172) and a tail shaft adapter ($276) . Those are the ones that I need to go from my Turbo 350 to the 4L60-E with a bell housing to. The shock Turbo 350 to NP-205 is still needed as part of the conversion. Since your trans came out of a 2wd, I would check with advanced to see if there is anything different needed.
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
Sold.
THE STORY HERE
Old 11-04-2007, 10:30 PM   #10
bdas70chevy
thanx i am getting the truck tomorrow and start getting parts off of it fun
Old 11-30-2007, 07:49 PM   #11
bdas70chevy
Befor i can start i need to get rid of the LT1 I have in the garge to make room for the other motors hope it goes fast
http://phoenix.craigslist.org/pts/492550780.html
