Old 10-25-2007, 03:24 PM   #1
Richard Dobson
Is the Adapter Plate OK?
I bought a 396 engine with a Edelbrock #1411 750 carb with a square bore adapter which is on the stock Chevy 3883948 intake manifold. The stock manifold is for a Quadrajet carb. Edelbrock spec's out a Quadrajet adapter plate #2696 for the 1411 on this manifold. I just want to get the engine running to see if it is OK, then later in the future I plan on putting on the proper Edelbrock intake for this carb. Will I be OK to use the square bore adapter for awhile? Will this cause poor performance? The PO said he had 10K on the engine after a rebuild. Thanks for any help.
Richard Dobson
Richard Dobson is offline   Reply With Quote
Old 10-25-2007, 03:32 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Is the Adapter Plate OK?
Should be O.K. you'll lose a little low end torque, but you probaly won't even notice...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-25-2007, 04:15 PM   #3
49m
49m's Avatar
I put an adaptor plate on mine an it works fine.
49m is offline   Reply With Quote
Old 10-25-2007, 04:28 PM   #4
Richard Dobson
49m, thanks for your reply. I am concerned because the PO used a square bore adapter for his Edlebrock carb instead of a quadrajet adapter like Edelbrock recommends for a stock Chevy quadrajet manifold. I guess he thought using a square bore adapter was like having a square bore manifold.
Richard Dobson
Old 10-25-2007, 08:45 PM   #5
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
I installed an adapter plate, supposed to incease high end performance, never noticed any difference in performance low or high. Reason I put it on was to be able to get another vac. port.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
