10-26-2007, 07:55 AM | #1 |
Tranny crossmember question
does anybody know if this crossmember from performanceonline.com can be used for either an auto or manual trans? It says its for an auto, but I was wondering if the mount is the same for both trans, but with different bolt hole mounting locations??
http://www.performanceonline.com/sto...cat=461&page=1 Last edited by jlaird; 10-26-2007 at 07:56 AM. |
10-26-2007, 09:39 AM | #2 |
It's a catastrophic success.
Re: Tranny crossmember question
Stock manuals mounted to the bell housing up close to the back of the motor, as the autos mounted on the tail of the tranny.
10-26-2007, 11:25 AM | #3 |
Here is another pic of man mount from another post.
10-26-2007, 12:16 PM | #4 |
Thanks for the pics!
10-26-2007, 01:20 PM | #5 |
Early manual trannys (3spds) were short & used the crossmember that was located immediately behind the back of the engine. Later manual trannys (that are longer/heavier) would need the same auto-trans style transmission crossmember to better support the additional length/weight.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-26-2007 at 01:23 PM. |
10-26-2007, 02:38 PM | #6 |
scoti,
I thought I read something like that. So would the later style manuals use both the crossmembers or just the further back one? |
10-26-2007, 02:46 PM | #7 | |
IIRC, the original truck bellhousings had provisions for the original style man trans c.member that went just behind the block. Aftermarket bellhousings (or those from a HP application) won't have these provisions.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-26-2007 at 02:50 PM. |
10-26-2007, 05:05 PM | #8 |
dimensionally the 3spd is the same or almost the same as the TH 350 (uses same driveshaft and yoke). There is also a spot on the three speed where a mount could bolt but I don't know if it is in the same place.
10-26-2007, 06:08 PM | #9 | |
I know you can bolt a 4spd up to the bellhousing & not use any trans c.member @ all. But it's going to cause issues sooner or later.
10-26-2007, 06:23 PM | #10 |
Yeah, a lot of weight cantilevered will put undue stress on the bellhousing. I suspect the opposite to be true of the 3spd with no support at the bellhousing might sag in the middle. I also notice the bellhousings designed for rear xmembers (no provision for the mounts) have deep fins for added strength and a lot if not all are aluminum which saves weight. An older 3 on the tree nova probably had a saginaw with the rear crossmember so getting that bellhousing setup might be a way to go. I know there are some car guys on here too who will know
10-26-2007, 10:05 PM | #11 |
Bowler Transmissions builds a awsome tubular cross member that works on both
