Old 10-26-2007, 08:23 PM   #1
MotorSeven
Restoration Desperation
MotorSeven's Avatar
'72 to '68 axle swap question.....
Ok, i researched here and found that the 72 axles will be 3/4 inch longer than the 68. My neighbor(an old school Mech) says that they will work, soooo i pulled a pair out of one in a local bone yard. Yep, they are longer, however, the drum from the 72 is 3/4 inch deeper.
My question is : Can i slap the 72 drums on the 72 axle in the 68 housing? It seems to me that as long as the bearing surface mates up and the brake shoes are covered it should work ...right? Anyone tried it?
This is just a temp fix, because i want to get the truck on the road....my rebuilt 350 is sitting on the garage floor looking very lonely........Eventually i am going to put in a posi.
RD
MotorSeven is offline   Reply With Quote
Old 10-26-2007, 08:26 PM   #2
ksjh1316
ksjh1316's Avatar
Re: '72 to '68 axle swap question.....
Man I wish I had the answer but its some more of the info I am looking for GL I will be watching as well.
PS Thanks for the rain measurement last night
ksjh1316 is offline   Reply With Quote
Old 10-26-2007, 09:21 PM   #3
Brad
Out of the carpool lane.
Brad's Avatar
It'll work, but the axles are hardened only on the original bearing surfaces meaning that when you have the new setup, the bearings won't be riding on a hardened surface anymore. You run a serious risk of the axles breaking. It'll probably be fine if only used for a few months or so.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 10-26-2007, 10:48 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
plus, there will be more leverage on the axle right by the bearing.
Many ppl have done it and gotten away with it.
I'd hate to have one snap at 70 MPH on the way to work.
Old 10-26-2007, 11:03 PM   #5
Jim_PA
I drove mine that way for over a year with no problems.
I ended up getting the 2 3/4 inch drums from like a 78 chevy or something...
Since then I put in a 72 posi rear, and went back to the 2" rear brakes.
I would only recommend it if you've got a line on some cheap big drums, and just want to get it on the road -- or if you plan on upgrading your backing plates when you go to the "correct" axle width, and keep the bigger rear brake drums.
I ended up buying 2 new sets of drums- one 2 3/4" set when I had the longer axles in, then.... when I went to the 72 rear, I had to buy a 2" set... Those things aren't cheap, but I was at the point of either getting all new backing plates and shoes to use my 2 3/4" drums, or just suck it up, and buy 2" drums for the 2" shoes and backing plates I already had on there. I don't think they had the wider shoes/drums in 72, unless there was a heavy-duty brake upgrade I wasn't aware of.
I hope that wasn't too confusing...
Jim_PA is offline   Reply With Quote
Old 10-26-2007, 11:31 PM   #6
MotorSeven
MotorSeven's Avatar
Hmmm, ok, thanks for the info, and i have to add....ARGGG! It looks loike i have to go back to the bone yard and get the rest of the rear end, but it's a 100 bucks as opposed to 40. I am going to start scrounging for a posi. Is there anyway to tell from the outside? And will a later model posi work? Sorry if this has been covered before......
RD
Old 10-26-2007, 11:39 PM   #7
Jim_PA
RD
No sure way to tell, and yes any 12 bolt truck posi will work, as long it is the same carrier series as the gears you want to use. I would look for one with clutches and springs as opposed to the type with weights (gov lock).
Old 10-27-2007, 10:34 AM   #8
MotorSeven
MotorSeven's Avatar
Since it stopped raining, and it ain't dark, i put the two axles side by side and measured from the clip grove to the bearing surface. The 72 axle has a longer bearing surface which will allow the bearings to ride entirely on the hardened surface with 1/8" to spare. Larger drums won't be a problem, and i think i can run this set up until i can find posi.
Now i have to get the 305 out, swap the front end, drop the 350 in. Thanks to JerseyGirl, i have a free set of headers, and i decided i am going with glasspacks.....takes me back to the "good ole days!"
RD
