Old 10-27-2007, 09:16 PM   #976
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
Originally Posted by skanave View Post
was that a subtle hint?
Do you think he got the hint???
CAL 58 GMC is offline   Reply With Quote
Old 10-31-2007, 12:13 PM   #977
02snoma
02snoma's Avatar
Re: 58 GMC Project
Yes, I got the hint! Only thing is...I dont get to drive it enough for me to get you carbs heads and intake
Any word from Custom Classic Trucks?
02snoma is offline   Reply With Quote
Old 10-31-2007, 10:10 PM   #978
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
I'll let you drive it around the block.......twice!!!
There's a car show Saturday at the Clovis Toy's R Us. It's the last one this year. Come by if your not busy, I can give you the Summit Racing parts numbers for the heads.
Old 11-01-2007, 11:59 AM   #979
02snoma
02snoma's Avatar
Re: 58 GMC Project
I would come by but I have Dave's wedding. I wish I could go. There is going to be a long wait til next spring til you can show the truck again. It will give you plenty of time to save up for your new engine parts
Old 11-03-2007, 10:27 PM   #980
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
Originally Posted by jplasse
Im new here and went through your whole 58 build thread. Looks sweet. Really nice work... inspired me to get started on a 57 chevy truck... hunting for an axle at the moment and was wondering how wide your rear s-10 axle was or what I should be looking for in width... I want rear disks also and 3:73 gearing or so... Ive got a 700r4 tranny and will be running 20's front and rear with a TCI mustang II crossmember, controls arms, spindles etc.
So basically I was curious of width of your rear axle and where your measurment is from and what backspacing did you go with for your wheels?? What axle would you recommend that comes with the 5x4.75 lug pattern with discs and correct width? I noticed you ran adapters/spacers... did you NEED spacers or just get them because of the wheel order mistake?
Thanks for the help!
Johnny
First of all let me say welcome!
Only the S-10 blazers from 1998 to 2003 had rear disk brakes. None of the S-10 trucks had them. There are two sizes from the Blazers, the first is 58 inches wide and that one comes from the 2 wheel drive. The second is 60 inches wide and it was on the 4 wheel drive. There is draw backs to both of them, but they can be worked through. On the 58 inch, the caliper comes slightly in contact with the rear spings in the stock location. It can be corrected by using a flip kit and using 2 inch lowering blocks with a C-notch or use a four link in the rear. The 60 inch also has problem. The calipers will hit the bed sides and have to be notched to clear the caliper. This is what entourageguy had to with his and he also used a 4 link. I used the spacer so I could use the 2 wheel drive rear end and I could get a 10inch wheel with a deep dish.
Since there I have a lot of detail here I will post this on my build thread to share with everyone else.
Old 11-14-2007, 03:08 PM   #981
tiggerstoy
tiggerstoy
tiggerstoy's Avatar
Re: 58 GMC Project
hi cal, did you use the new electric winshild wiper motor, and if you did, where did you buy it?....thanks....max.
tiggerstoy is offline   Reply With Quote
Old 11-14-2007, 05:06 PM   #982
entourageguy
Yellow truck club
entourageguy's Avatar
Re: 58 GMC Project
With the 60" the calipers are mounted up higher than the 58". I've c notched the my frame and have it low.The calipers hit the box just before the axle hits the bumpers in the c notch. I also used 2.5" spacers with the 15"x7" gm rally wheels. 2" would be better.. I'm going to do a small tub over the winter so I can get the rear right down.
Brian ...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 11-15-2007, 12:03 AM   #983
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
I have the stock electric wiper motor.
Old 11-24-2007, 04:34 PM   #984
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
Okay, so the car show season is over for the year and winter is almost here. It's time to start my winter project. I broke down and bought the intake, carbs & heads I was thinking about buying. My son and I will start installing them this weekend. Here's a few pics.
Old 11-24-2007, 04:40 PM   #985
tiggerstoy
tiggerstoy
tiggerstoy's Avatar
Re: 58 GMC Project
sweet!
Old 11-24-2007, 05:33 PM   #986
solidaxel
solidaxel's Avatar
Re: 58 GMC Project
I LOVE Christmas gifts to me from me!!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-24-2007, 05:54 PM   #987
watahyahknow
watahyahknow's Avatar
Re: 58 GMC Project
oh nooooo its the beginning of the end , next thing you know he be dropping by nelson racing for one of there 1100 hp turbo kits .
oh whell milage out of the window but other than that nuttin but fun right ?
hope you got the progressive linkage kit on those dual carbs
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 11-25-2007, 01:07 AM   #988
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
Yep, the kit was complete with the linkage all the way to intake gaskets. As for gas mileage.....will if I can keep my foot from slamming the pedal to the floor I thank I will be okay.....well maybe?
Old 11-25-2007, 02:21 AM   #989
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: 58 GMC Project
Just finished reading this whole thread and damn what a bad ride you have built.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-25-2007, 10:50 AM   #990
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
Thanks FREBCHBLUE! It was alot of work, well worth it now that I can cruise it down the road.
Old 11-25-2007, 02:41 PM   #991
entourageguy
Yellow truck club
Re: 58 GMC Project
Hey Cal
I looked and saw you had posted on your forum and thought " what the heck is this guy going to do now"? Nice choice on the engine add ons.
I've got my truck in the garage at home as it never made it to my usual storage spot before the snow and salt hit the ground.
I'm already cruising the sites on the net wondering what to do for next year.
Brian ...
ps unfortuntly I've also got it up for sale.
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 11-26-2007, 01:01 AM   #992
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
Originally Posted by entourageguy View Post
Hey Cal
Brian ...
Hey Brian, whats up with your truck for sale?
Old 11-26-2007, 07:17 AM   #993
entourageguy
Yellow truck club
Re: 58 GMC Project
Cal
Time to start thinking of the family. My oldest daughter has autism and is in high school. Moneys tight and she has to continue her education and college/university is around the corner. With two other kid in high school I think I need a few $$ in the bank. We'll see what happens.
Brian ...
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 11-26-2007, 11:56 AM   #994
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
I understand, the family should always come first. Cars & trucks can be replaced, but family can't. Although sometimes it feels kind of like your ride is a part of your extended family. Even though you sell your truck and I'm sure everyone would agree, your still apart of our truck family here! Good luck on your auction, I hope you get top dollar for your truck.
Old 11-26-2007, 12:50 PM   #995
Steve Kelly
Cool Re: 58 GMC Project
Originally Posted by extd56 View Post
If you are looking for a custom stepside bed let me know, I am selling one that I did not use for my extended project.
what is the extended cab on the other truck you have,and what did you use a sub or two truck cabs.
Steve Kelly is offline   Reply With Quote
Old 11-26-2007, 05:16 PM   #996
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
Hey Steve, You need to PM extd56 to find out. I don't think he reads my thread. By the way, Welcome!!
Old 11-28-2007, 11:52 AM   #997
02snoma
02snoma's Avatar
Re: 58 GMC Project
Ever find that rocker washer? Hope it did not fall into the black hole! I cant wait to finish the engine. We should be able to put it back together in the same amount of time it took to strip it down.
Old 11-28-2007, 06:50 PM   #998
entourageguy
Yellow truck club
Re: 58 GMC Project
cumon Cal
Brian ...
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 11-28-2007, 10:01 PM   #999
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
I don't know if it's in the"black hole". I sure hope it not or I'm screwed.
It will take more time to put back then it did to tear down since were going to have to tork everything back down and adjust the valve's.
Old 11-28-2007, 10:04 PM   #1000
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 58 GMC Project
cumon Cal
Brian ...
Pictures to come buddy! By the way, this is the 1000 th post on this thread!
