Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 10-28-2007, 11:11 PM   #1
BAD4X4
BAD4X4's Avatar
What size bolts do you use in your Blazer top?
Question for all you blazer guys. I got a new top for my blazer and was wondering what size bolts typically go in these. My old blazer top used fine thread 3/8 and the new top looks to be a 5/16 course thread, but don't screw in real easily??? Any help or suggestions would be greatly appreciated...
Dana
1972 Cheyenne K-30 6"lift {502 PROJECT}
1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue}
1972 Cheyenne K-20 Custom Stretch 6" lift 454
1972 Custom Deluxe K-20 4" lift
2007 GMC Crew Cab Diesel 6"lift {The Tow Rig
2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's)
1977 El Camino SS Grandpa baught new
1986 K-30 Crew Cab 502
1955 Chevy 2-Door gasser 454 550hp{project}
1956 Chevy Bel-Air 2-Door hardtop 572 700hp
1979 Ford F-350 All Original 4x4 (Wife's)
BAD4X4 is offline
Old 10-29-2007, 12:27 AM   #2
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
Re: What size bolts do you use in your Blazer top?
My 70 has the 3/8" SAE thread. Whatever you do IMHO make sure you put antiseize on them before installing!
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline
Old 10-29-2007, 01:00 PM   #3
truckster
truckster's Avatar
Looks like mine (72) are 5/16 coarse. I'd recommend you use flat washers under the heads of the bolts to protect the fiberglass.
truckster is offline
Old 10-30-2007, 10:32 AM   #4
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here are the bolts used for my 71,single walled top.
I used stainless fasteners for the bedrail.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline
Old 01-20-2009, 12:05 PM   #5
Livrat
Member #1049
Livrat's Avatar
All of my Blazers have hex head 5/16 coarse thread bolts, they look almost like a fender bolt but have a flanged head.. (built in washer)
Livrat is offline
Old 01-20-2009, 06:26 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
slightly off topic, the single wall tops, where the bolts go down, is the bed side threaded?
This will be marked for FAQ.
Longhorn Man is offline
Old 01-20-2009, 06:39 PM   #7
Old Chevy Mech
Keepin it runnin!
My Parts Blazer is a 72 single wall and no the bed is not. Nuts & washers are used.
1970 K-5 4X4 Blazer
Old 01-20-2009, 10:45 PM   #8
BobbyK
BobbyK's Avatar
My bedrail is threaded.
Is it factory?...who knows.
I blew up the pic so you could see that every other hole is threaded.
BobbyK is offline
Old 01-23-2009, 10:30 AM   #9
jaros44sr
jaros44sr's Avatar
My '72 has both holes, single and double. The ones that bolt from the top are attached with nut plates that can slide a little for adjustment
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline
Closed Thread
