Old 10-31-2007, 03:54 PM   #1
DURRTY
USMC
DURRTY's Avatar
front U joint is hitting the cross member
Is something missing? like a spacer were the cross member bolts to the frame? or is it tilted ?
once its locked in to 4wd and the pedal is pushed it beats the crap out of that cross member. the cross member had some serious wear on it from this.
any body have an idea why?
here are the pics
Semper Fi
DURRTY is offline   Reply With Quote
Old 10-31-2007, 04:51 PM   #2
earl87gta
earl87gta's Avatar
Re: front U joint is hitting the cross member
I would think that maybe its just not high enough off the cross member or not the corect crossmember. did you put that transfer case in the truck? Thats not the case that came in a 71 so Im thinking it may have been hiting it since it was instaled. you may find you need to put a spacer in between it and the frame and the adaptor to lower it down out of the way some.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-31-2007, 07:18 PM   #3
LONGHAIR
What year is the truck? That looks like a 208 transfercase....that should be mid 80s?
LONGHAIR is offline   Reply With Quote
Old 10-31-2007, 08:20 PM   #4
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
The mounts look pretty mushed too.
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 10-31-2007, 09:46 PM   #5
Southedisto
River life......
Southedisto's Avatar
Mounts and could be the gimbal ring is worn. Definitely not the stock tcase though.
Southedisto is offline   Reply With Quote
Old 10-31-2007, 11:20 PM   #6
Old Chevy Mech
Keepin it runnin!
How much lift do ya have?
Frank
1970 K-5 4X4 Blazer
Old 11-01-2007, 02:03 AM   #7
DURRTY
USMC
DURRTY's Avatar
I should have given the lift and year and drive train specs DUHH !!
Its an 83 GMC short step side I don't know if it was originally a step side. It has a bow tie grill and no GMC marks left on it. but it came up as a GMC on the title
also it has a FF 14bolt rear and a 3/4ton D44 in front( it has 8 bolt axles on it so it may well be a 1/2ton with 8 bolt axles)
4 inch ORD shackle flip in the rear and 4 inch springs in the front. 3 inch body lift
The cross member in the pic is bolted directly to the frame it seems like a bushing should be there to me. I have one for my 205 in the blazer tomorow Ill see if it would fit in there...
Earl....
I just bought this truck recently I couldn't stand not having a truck to beat on. My blazer is going to take 6 more months at least and this truck was way to good of a deal to pass up.
Semper Fi
Old 11-01-2007, 02:15 AM   #8
earl87gta
earl87gta's Avatar
I would try and change the TC ruber mounts and see if it helps they look worn out. if that doesnt do it you could add a spacer between the frame and the crossmeber.
Earl
Old 11-01-2007, 03:59 AM   #9
DURRTY
USMC
DURRTY's Avatar
that sounds about good..... I'm going to get fresh rubber mounts under it this weekend.
Then if it still hits Ill separate that cross member a half inch or so from the frame.
Any one have a similar year truck with the single cross member( my blazer has 2 ) and does it mount directly to the frame like this?
Semper Fi
Old 11-01-2007, 04:47 AM   #10
earl87gta
earl87gta's Avatar
you must have the skid plate on the blazer thats why it has 2. no skid plate and they only have 1
Earl
Old 11-01-2007, 04:48 AM   #11
earl87gta
earl87gta's Avatar
I can crawl under the 83 burb I have and snap some pics for you if you like
Earl
Old 11-01-2007, 04:58 AM   #12
DURRTY
USMC
DURRTY's Avatar
roger. I have the skid plate. and I did not know that was all that second cross member did...
if your burb looks the same or real similar to what i have going on just let me know but if its different I would like to see what is going on.
Semper Fi
Old 11-01-2007, 05:05 AM   #13
earl87gta
earl87gta's Avatar
I look when I get home I dont remeber what it looks like under there.
Earl
Old 11-01-2007, 06:07 AM   #14
68K20 x Drill
My 84 Burb looks just like that, but with better tranny mounts.
You are missing the right side transfer case to bellhousing brace bar.
Have a look at your right side motor mount,if it's done, it could be tilting the whole assembly...I just changed engine mounts on mine, and it lifted the motor an inch.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 11-01-2007, 06:30 AM   #15
...mounts.
