Old 10-31-2007, 07:31 PM   #1
75shortysocal
350+dual flows= fun :)
75shortysocal's Avatar
exhaust clearance, 5/7 drop?
i think i screwed myself over by getting long/full tube headers.... can i still slam 5/7 drop with these headers or will i have to buy new headers before i even slam?
you cant really see it in the pic....but the headers do sitcloser to the ground, then the frame...is theer any way for my to check if it will have enough clearance to slam?...im thinking just take a tape measure and see if the headers will be in the ground if i drop 5 inches....
any suggestions?
plus, i still have big alterain tires , so that might also be a problem?
untill i get my permentant tires..
ALWAYS CHECK YOURE FRONT WHEEL BEARINGS!!
SPINNING OUT ON THE FREEWAY DUE TO THE BEARING GOING OUT IS PRETTY HAIRY!!!
75shortysocal is offline   Reply With Quote
Old 10-31-2007, 07:52 PM   #2
75shortysocal
Re: exhaust clearance, 5/7 drop?
the lowest part of the exhaust is about 9 inches above the ground.. so, after the drop it would be about 4 inches above the ground....is that to low to drive?
Old 10-31-2007, 10:05 PM   #3
tvblazer78
Low & Fast!
tvblazer78's Avatar
I have air on mine and it is about 2" from hitting with all the air out of the bags. Here is a pic with all the air out and you can see the headers..
tvblazer78 is offline   Reply With Quote
Old 10-31-2007, 10:38 PM   #4
Rc 415
Flat Black, & Chrome!
Rc 415's Avatar
I roll my truck with +/- 4" of clearance at the lowest part of the exhaust every day, anytime I scrape its usually the lower control arm when going over a bump, I havent had the exhaust hit YET...
1983 Chevy C10 Stepside Sold
http://s69.photobucket.com/albums/i76/rc_415/
Rc 415 is offline   Reply With Quote
Old 10-31-2007, 10:41 PM   #5
Rc 415
Rc 415's Avatar
by the way you aren't going to be able to drop your truck 5" in front with those tires...
Old 10-31-2007, 10:54 PM   #6
BaddBusa2005
BaddBusa2005's Avatar
nevermind im a retard
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq
BaddBusa2005 is offline   Reply With Quote
Old 10-31-2007, 11:14 PM   #7
75shortysocal
yea, these tires are all-terain.. im getting new rubber all around...will i need the new tires before the drop?
Old 10-31-2007, 11:41 PM   #8
Rc 415
Rc 415's Avatar
In the front ... yes, that is unless you are willing to pull the inner fender wells, or you are going to leave the truck sitting, because it wont roll with tires that tall up front.
