10-31-2007, 07:32 PM | #1 |
Small Block New Thumper Camshaft
I HAVE A BRAND NEW ENGLE HYDRAULIC HOT ROD CAMSHAFT. this has never been in a engine. its a maxed out hydraulic grind like for pro street performance etc. power band is from 2500-7000 rpm,s . its recomended for 10-1 compression and up. if you want a cam that racks off this is it. i paid almost 300.00 for this and i,ll sell it for 125.00 delivered.
bob spec,s. in. 520 - exh. 537 lift in. 294 - exh.310 diration
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 11-01-2007 at 12:18 AM. |
10-31-2007, 10:43 PM | #2 |
Re: Small Block New Thumper Camshaft
ttt
I BELIEVE IN JOHN 3:16 |
11-01-2007, 08:17 AM | #3 |
So this is an Engle cam, not a Comp Cams Thumpr cam, right? I couldn't find it on the Engle Cams website. What's the duration at .050 and the Lobe Seperation Angle(LSA)? Is it flat tappet or roller? Any part #? Thanks
70 Custom/10, 396, Muncie 4spd, SWB SOLD 72 Cheyenne K20, 350, Granny 4spd, LWB, daily driver 72 Cheyenne Super C20, 350, Turbo 400, LWB, parts truck for 4WD Cheyenne |
11-01-2007, 12:49 PM | #4 |
grind number EP28/30-HYD, INTAKE OPEN @20 EX CLOSES @22, INT. CLOSES @48 EXH. OPENS @ 58, GROSS CAM LIFT INT. 347 & DUR.@.050 IS 248,
GROSS CAM LIFT EXH IS 358 WITH DURATION 260 @.050. LOBE CENTERS 106 ITS A HYDRAULIC LIFTER CAM , BIG AS YOU CAN GET AND WHAT THE ANTI PUMPUP LIFTER IS CAPABLE OF. ITS NOT IN THE ENGLE BOOKS ITS A SPECIAL HI-PERF SBC CAM FOR PRO-STREET USE.
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 11-01-2007 at 12:50 PM. |
11-01-2007, 06:01 PM | #5 |
Do you have the cam card with this? Any lifters to go with it? Are you flexible on the price at all? Thanks
11-01-2007, 07:47 PM | #6 |
MAN I,AM TAKING a big hit as it is. 125.00 delivered is about giving it away. it was over 300.00 after shipping. no theres no lifters just a brand new cam.... and yes the cam card is with it from engle.
bob
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 11-01-2007 at 07:48 PM. |
11-02-2007, 01:21 PM | #7 |
Ttt
11-02-2007, 07:02 PM | #8 |
Well, if you get to the point where you'll take $100 shipped, let me know. Not trying to offend and if you can't go that low, no problem. Thanks
11-02-2007, 07:03 PM | #9 |
i wont go that low and you wouldnt also. but thanks
11-28-2007, 04:47 PM | #10 |
ttt
