Old 11-02-2007, 05:01 PM   #1
salazar44
65 - Chevy C10
salazar44's Avatar
removing column shifter knob
I wanted to put on a new column shifter and blinker knob. I was thinking that they unscrewed off but instead, they just keep spinning. Any idea how to get them off?
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 11-02-2007, 06:10 PM   #2
cstanley
cstanley's Avatar
Re: removing column shifter knob
column knob pulls straight off - not easy
don't know about blinky.
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 11-02-2007, 06:42 PM   #3
salazar44
65 - Chevy C10
salazar44's Avatar
are you sure? I pulled pretty hard on that bad boy!
VIC
Old 11-02-2007, 11:47 PM   #4
fchava
fchava's Avatar
turn signal should be threaded, the shift knob I cut off. I used a dremel then split it.
fchava is offline   Reply With Quote
Old 11-03-2007, 04:18 PM   #5
salazar44
65 - Chevy C10
salazar44's Avatar
OK.. so you cut it off and then threaded it? What did you put on afterward? I have a little lathe here at work now, And I wanted to fab something up from some scrap aluminum we have.
VIC
Old 11-04-2007, 01:43 AM   #6
fchava
fchava's Avatar
sorry I was wrong about the turn sig arm. I bought the billet kit from the truck shop. I have a 70's van column. the turn sig is probably pressed on cause the kit comes with a new arm and knob. The replacement shift knob is just held on with a allen screw through the side.
