People know me
those with 8"+ lift..........
What have you done for driveline angles? I am getting a slight vibration slowing down and taking off, I have 8" suspension lift with 35's. 465/205 and dana60 rear. What have you done?
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
Re: those with 8"+ lift..........
Is it only in 4wd or does it do it in 2wd too. It sounds like its time to upgrade to some new highangle drive shafts. you could also move the front axle forward some and the rear axle back.
Earl 68 2500 4x4 GMC Burb |
People know me
no front driveline yet.......Its sitting in the garage, but I figure if I dont have one in I wont be tempted. I do have a zerorate in the back and moved the rear axle back already. I have been looking for a bronco driveline to use, but just wondering what everyone else has done. I know the bronco one is only 1/2 ton, But I dont care it just sees the street and I never get on it, so it is pretty much babied all the time
Cochino_Racing_909
Here is my Jimmy! 8 1/2 inch lift 35 inch super swamper's tsl's
#5 | |
People know me
Have you driven it? Get a vibration? what do you have for a driveline?
myn did that with a 4 " before the Zero rate in the back springs. i think it is the drive line angle.
CV joint with pinion rotation.
![]() Join Date: May 2006
Cool, nice mod. How'd I miss that? Is it mounted behind the pinion nut? You keep changing that and it's not going to look like a first gen.
![]() I don't see any cables going to it, how does it work?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 11-04-2007 at 01:55 PM. |
