Old 11-04-2007, 11:28 AM   #1
H8tulooze1
H8tulooze1's Avatar
Exclamation Coil Spring 4x4 swb?
I did some searching on this site and could not find it. I wanted to know if they ever made a swb coil spring 4x4?
H8tulooze1 is offline   Reply With Quote
Old 11-04-2007, 12:38 PM   #2
earl87gta
earl87gta's Avatar
Re: Coil Spring 4x4 swb?
no chevy or gm truck came that way.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 11-04-2007, 05:29 PM   #3
1969k10stepside
If it's a coil spring rear,its probably a 2wd converted to 4wd..Chevy didnt use coils on 4wds till 88 with the IFS front end
1969k10stepside is offline   Reply With Quote
Old 11-04-2007, 06:02 PM   #4
Jtrux
I'm a poor spectator
Jtrux's Avatar
I've seen a 2wd converted to 4wd with coils all the way around. I gotta say it looked pretty good and it probably rode pretty nice as well.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 11-04-2007, 06:34 PM   #5
Zoomad75
K5Camper
Zoomad75's Avatar
The 88 and up trucks still used leafs out back too. The IFS used torsion bars, no coils at all. It wasn't until the GMT800 SUV's came along that GM started using coils in the back. Again that was on the SUV's only and except for the H2 Hummer, 1/2 ton's only. 3/4 ton subs and avalanches came with leafs out back too. Now coils up front on 4wd full size trucks didn't come until the 2007 GMT900 trucks came out with coil-over struts.
Back on subject, coils on 4wd solid axle trucks. People have done it, but it will require a complete 3,4 or 5 link arrangement to locate the axle as the coil would only support the wieght. Leaf springs perform both functions of supporting the wieght and locating the axle. So if you take the leafs away, you got to put something back to position the axle/connect it to the truck.
Changing over to coils is not an easy operation and requires you know some stuff on suspension design. Until ORD comes public with their coil-over 4 link conversion, nobody sells a bolt on kit to ditch the leafs on a solid axle gm truck.
If you want an example of what it takes to link up a solid axle trucks, there was a thread in the suspesion section of this site that did just that. He linked up the front and rear of a 70 or 71 K10 so he could run airbags front and rear. He wasn't putting bags on to drop it, just to give a really soft ride and give some adjustment up and with loads. Took a lot of fab work to link it up. I'd post the link, but couldn't find it with the search function here...
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 11-04-2007, 06:57 PM   #6
earl87gta
earl87gta's Avatar
here is the air bag thread http://67-72chevytrucks.com/vboard/s...d.php?t=200909 you could also look at a doge truck they were all coils up front from I think 93 until now.
Earl
