Old 11-05-2007, 05:32 PM   #1
extd56
extd56's Avatar
Engine RPM
What is a good RPM for a 69 Chevy truck 4x4 with a 350/350 trans and a 6" lift and runnign 35" tires. It is going to be a heavy rig when I am done with it.
extd56 is offline   Reply With Quote
Old 11-05-2007, 05:42 PM   #2
wibilly
wibilly's Avatar
Re: Engine RPM
your ? is pretty vague. are you talking cruse rpm? what is the truck being built for? what gears? what are you going to do to the engine? we need more info
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 11-05-2007, 06:00 PM   #3
cdowns
cdowns's Avatar
Re: Engine RPM
put some 5:13 gears in and wind it up to 6 or 7 thousand
Old 11-05-2007, 06:23 PM   #4
mnunn454
mnunn454's Avatar
Re: Engine RPM
If it's lugging at all with that huge torque and weight load and with all that wind resistance, you'll be burning even more gas than you would if it weren't lugging. So I'll venture a guess at around 2500 to 2800 RPMs when cruising on the highway. This should ensure the engine's not lugging and your manifold vacuum stays in a decent range.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 11-05-2007, 06:29 PM   #5
extd56
extd56's Avatar
Re: Engine RPM
I was thinking of the RPM at cruising speed of 65-70 if I can keep it at that speed as I tend to speed a little I will be running 35" tires on the truck and I figured that my cruising RPM would be about 2450-2500 at 65. I will be running a 91 350 with TBI and the truck will be used mostly for hauling me around, not too much towing or off road use.The truck is my crewcab 69 so I would think it will be pretty heavy and lots of wind resistance no matter what I do. I have a 4L80E and 241 transfer case that I could put in it but I think I am better off staying with the 350 trans and 205 transfer case. Thanks
Old 11-05-2007, 07:37 PM   #6
Mudder
Mudder's Avatar
Re: Engine RPM
With 4.10's and 70 mph mine turns in the upper 20's on the highway.
Mudder is offline   Reply With Quote
Old 11-05-2007, 10:49 PM   #7
68K20 x Drill
Re: Engine RPM
Mine weighs about 6000, and I get about 70 MPH out of 3000 RPM.
Ratio seems good all around, but not as good as more gears would be.
I would be inclined to ditch the TH350 unless it is seriously built.
Every time I drive on pavement, I try to shift to a higher gear that I don't have.
http://www.cartestsoftware.com/cartest2000/index.html
If you download and install the demo, this is a pretty good little program for figuring your performance with various engines, gears, weights, wheels, etc.
If you input is accurate, the results are pretty spot on.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
