Old 11-05-2007, 11:11 PM   #1
nac593
harmonic balancer change?
I'm switching from manual trans to automatic. Can I still use the same harmonic balancer or does it require a different one? Thanks
nac593 is offline   Reply With Quote
Old 11-05-2007, 11:14 PM   #2
Billla
Billla's Avatar
Re: harmonic balancer change?
The only time a balancer change is required is when you change the balance Seriously, not required as long as you match the flywheel to the flexplate - i.e. if the flywheel was external balance then the flexplate must be as well.
Billla is offline   Reply With Quote
Old 11-05-2007, 11:33 PM   #3
nac593
I'm not sure I understand. Does that just mean I have to have the same number of teeth on both?
Old 11-05-2007, 11:45 PM   #4
Jtrux
I'm a poor spectator
Jtrux's Avatar
No, engines are balanced, either externally or internally. Look on your flywheel, if it has a weight on it, then it's external if not then it's internal. Your new flexplate also needs to match your old flywhell in balance and teeth (unless you want to buy a different starter).
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 11-05-2007, 11:51 PM   #5
nac593
Thanks for the help.
Old 11-06-2007, 07:15 AM   #6
70GMCer
70GMCer's Avatar
Unless you have a 400 sbc or a 383 stroker, you will just use the regular flexplate. As said above, just make sure you have the same tooth count as your flywheel has.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
