Old 11-06-2007, 01:01 AM   #1
70 GMC Trucker
70 GMC Trucker's Avatar
Tips on Installing Power Steering
I'm about to install power steering on 70 GMC and wondering if there is anything to watch out for or advice on the order of things to install. I took the pump,pulley and box from a 78 C20. Thanks
70 GMC Trucker is offline   Reply With Quote
Old 11-06-2007, 01:18 AM   #2
70C10Step
70C10Step's Avatar
Re: Tips on Installing Power Steering
I would like to know also???
All Toys:
1971 C10 Fleetside - I needed it!
1970 C10 Stepside - Midlife Crisis
1969 C20 3/4 Longbed - Beast!
1966 Mustang Fastback - Daily Fun
1965 Mustang Fastback - Money pit!
70C10Step is offline   Reply With Quote
Old 11-06-2007, 01:23 AM   #3
berencam
berencam's Avatar
have ya got the pumps brackets? they can be pretty hard to find.
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 11-06-2007, 01:25 AM   #4
70C10Step
70C10Step's Avatar
I have a 71 setup and a setup off a 86 Van...
All Toys:
Old 11-06-2007, 01:28 AM   #5
70 GMC Trucker
I have the pump, brackets, hoses, double crank pulley and steering box.
Old 11-06-2007, 01:31 AM   #6
berencam
berencam's Avatar
then thats about all the help i can give you ive never personally done a install on one, just know thats a common problem people run into
Old 11-06-2007, 01:36 AM   #7
berencam
berencam's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=216886
that might help you guys tho.
Old 11-06-2007, 02:01 AM   #8
70 GMC Trucker
Thanks Berencam for the info and hope your feeling better !!!
Old 11-06-2007, 02:04 AM   #9
berencam
berencam's Avatar
nothing a few asprins cant handle, cant say the same for the vehicles, and david.....
Old 11-06-2007, 05:56 AM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Swap the box and pitman arm.
Install pump and belt.
Connect hoses, fill and bleed.
Enjoy.
If you have everything you need, plan on 2 hours of work. The pump brackets can be tedious, particularly the one bolt that goes through the engine mount.
Beware though, that 70 model truck and your 78 donor use drastically different pump and brackets. The boxes interchange though.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
