Old 11-06-2007, 06:24 PM   #1
m.lander
tranny fluid type
could type F tranny fluid be run exclusively in a th 350 with a mild shift kit
m.lander is offline   Reply With Quote
Old 11-06-2007, 06:56 PM   #2
hvychve
To The Levy
hvychve's Avatar
Re: tranny fluid type
WHY????
why would you want to put a ford fluid that is for fords, dexron 2 or 3 would be what you want , and should be readily available at every auto parts store you can find, I would guess even your grocery stores will stock it,
If my memory serves me, and maybe someone can correct me, the friction material is in the ford fluid and on a gm it is in the material of the bands and clutches, I suppose it would work , but I would wonder why you would even want to use it, I personally would stick with what it calls for , dexron type fluid
hvychve is offline   Reply With Quote
Old 11-07-2007, 06:17 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
OI have heard tranny builders say it is better stuff, but they also said you had ti use exclusivly the F stuff and never mix the two.
If it's a fresh rebuild, I say get mobile1 dextron.
Old 11-07-2007, 09:52 AM   #4
WorkinLonghorn
WorkinLonghorn's Avatar
Yeah,what LM says. FWIW,I used to work in AAMCO shops and that's all we used, shift kit or no.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 11-07-2007, 02:46 PM   #5
70rs/ss
70rs/ss's Avatar
B&M says to use type F after thier shift kit is installed.
70rs/ss is offline   Reply With Quote
Old 11-07-2007, 08:28 PM   #6
corn
Type F is almost the same thing as B&M's "trick shift". Ive always had good luck with type F with shift kits...
corn is offline   Reply With Quote
