Old 11-08-2007, 12:53 PM   #1
C10 - C90 Bill
C10 - C90 Bill's Avatar
6-Speed Conversions?
I was just talking to someone about 6-Speed Conversions and wondering if anyone out there knows of any kits available for our '67 to '72 trucks.
I have a '72 C-10, 307, 3-Speed.
Not sure I want to convert to one, but I am interested enough in one to read up on them and to consider what the cost would be.
Any info would be appreciated.
C10 - C90 Bill is offline   Reply With Quote
Old 11-08-2007, 01:18 PM   #2
greasemonkey
greasemonkey's Avatar
Re: 6-Speed Conversions?
crazylonghorn has a Richmond 6 speed in his truck, hopefully he'll chime in here.
I am planning on a Tremec 5 speed swap myself, classicchevy5speed has really complete kits available.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 11-08-2007, 06:54 PM   #3
C10 - C90 Bill
Thanks,
I checked out ClassicChevy5Speed and that TKO-500 looks pretty good.
But are there any complete kits out there to install one if I already have my own trans?
Old 11-08-2007, 07:33 PM   #4
crazy longhorn
Fabricate till you "puke"
There a couple shots of the Richmond http://community.webshots.com/user/hotrodhorn pretty straight foward bolt in, but the shifter is a long way back for a bench seat....L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-08-2007, 07:37 PM   #5
69halfton
69halfton's Avatar
i figured it out one time,
if my memory serves me,
its about 4 grand to swap out to a richmond 6 speed, all from summit racing.
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 11-08-2007, 08:18 PM   #6
crazy longhorn
Yea, it did take a BIG bite out of the wallet it went in where a 400 turbo came out , with no driveline mods(26 spline clutch, & move the crossmember). I run a stretched high hump pan, with a custom shifterbox added to the rear. the 400 slipyolk works also....L
Old 11-08-2007, 08:38 PM   #7
LS1powered67
LS1powered67's Avatar
Contact Keisler Engineering they should be able to hook you right up, if you want any further information I swapped a t-56 into my '67.
1967 C10, Short & Wide with LS1 & T56.
LS1powered67 is offline   Reply With Quote
Old 11-08-2007, 10:42 PM   #8
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
thats the plan for mine, carb'd LSX with a T56
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-08-2007, 11:07 PM   #9
68K20 x Drill
I put an ROD 6 speed in a 59 'Vette. Custom trans crossmember and driveshaft shortened 3" or so from Muncie 4 speed. Then 3 of us spent a day working on moving the Long shifter forward, and we got 7/8" out of it. I had to trim the body a tad for the shifter, but the hole in the console was just big enough. All the stock clutch and bellhousing stuff worked fine. No kit was available,and I think with the shifter he was $3600 into parts. Besides the shifter, it was a pretty easy fab job.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 11-08-2007, 11:22 PM   #10
chevy72blu
chevy72blu's Avatar
PLEASE make a build page when you do it. Im already drooling
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 11-10-2007, 02:19 PM   #11
TravisH
TravisH's Avatar
well heres something to hold you
TravisH is offline   Reply With Quote
Old 11-10-2007, 04:07 PM   #12
shifty
Questionable
shifty's Avatar
Pics are always appreciated
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 11-10-2007, 04:32 PM   #13
69halfton
69halfton's Avatar
im looking into it a bit...
does a richmond 6 speed fit into the automatics transmission tunnel?
or is there ALOT of cutting needed?
- Jason
Favorite caption:
Old 11-10-2007, 04:36 PM   #14
jkade
jkade's Avatar
Guys come on, get u a used t56 and save some money.
jkade is offline   Reply With Quote
Old 11-10-2007, 08:00 PM   #15
crazy longhorn
My truck is body dropped, & the 400 turbo didnt fit the stock (low hump ) tunnel. I cant answer that ? for sure, but I think if you are in correct factory small block spot, it would be pretty close. I run I 6 spot on the stands, & it took a stretched High hump to fit the trans & shifter. The shifter mounts high & right at the rear of the trans.....that would be the trouble spot. L
Old 11-11-2007, 11:14 AM   #16
C10 - C90 Bill
What was the T56 originally used in?
You'll have to excuse my knowlegde as it pretty much stops at 1972.
Old 11-11-2007, 11:33 AM   #17
piecesparts
Parts and more parts
piecesparts's Avatar
Do you have the part numbers and info from your install? I have a 68 C-10 that I would like to do a six speed mod, vice the 4L60E that came with the LS-1 motor that I have to put in it. The seats and the driveline are no problem here.
Old 11-11-2007, 12:51 PM   #18
chevy72blu
chevy72blu's Avatar
That is nasty, my friend. Seriously. Nasty. Sick nasty, even.
is the LS1 stock except for that intake?
RIP EastSideLowLife
Old 11-11-2007, 12:53 PM   #19
shifty
Questionable
shifty's Avatar
Some that come to mind are: Corvette, Camaro, Firebird, Viper, GTO, Mustang, Cobra, etc. There may be more. Both Borg-Warner and Tremec make a T56, and you will see there is the TKO also, which may or may not be related.
Old 11-11-2007, 02:04 PM   #20
NONHOG
NONHOG's Avatar
Just curious was it a pain setting up clutch pieces , is there a kit or did you find a donor truck ?
I have a ROD I am thinking about swapping out the T350 for.
thanks....
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 11-11-2007, 03:00 PM   #21
TravisH
TravisH's Avatar
Thats a LS 364, which is the LS2 that GM offers with the manifold in a crate. Dealer gave me a price where I couldn't justify stroking my 350. Of course I spent it all again on the tranny but it makes me happy
Now if only ECE would get those sandersons made
Old 11-11-2007, 05:41 PM   #22
crazy longhorn
thanks....
I run a 66 truck bell(4 11/16" center hole), the flywheel is a Hayes billet(you can run stock). The centerforce clutch set is a bolt in 11" set for the truck, but runs a 26 spline hub instead of the 10 spline truck pc. All of the stock clutch linkage pcs will work, but the rod ends "free" things up a bit. The trans is close enough in lenght to a 400 turbo, & has the same spline to use the 400 slip yolk. I would say if you run factory sb spot, use a 6 cyl /4spd 2wd high hump pan(they are a little longer), & modify as needed. IMO, the tin work is easy. My trans crossmember is custom built, but you can modify a factory auto trans member to fit the bill. Your 350 turbo is also close in lenght, but needs a slipyolk change. If your 2 pc shaft has a slip in the middle, you can "fudge " on the lenght a bit also.....just be sure to have 3/4-1" of slip, so you dont slam the trans. If you get into the build, & have any ?, feel free to ask......jog this old mans memory, on anything left out. best of luck,L
Old 11-12-2007, 12:56 PM   #23
jfalesi
Junior Member
Dam nizzle, that shizzle is fo' rizzle
jfalesi is offline   Reply With Quote
Old 11-12-2007, 09:37 PM   #24
memphismatt
memphismatt's Avatar
what?
memphismatt is offline   Reply With Quote
Old 11-13-2007, 12:58 AM   #25
68GMCCustom
Now I'm drooling!
The LS 364/440 w/MSD ignition was what I had originally planned on for mine, but then decided I wanted to go with the LSX block. Its iron so it can be bored conventionally, has 6bolt mains, accepts all LS1/LS2/LS6/LS7/L92 parts(including 6 bolt heads), bore x stroke goes up to something like 511ci, and it can handle up to 2500hp...which is a lot more then mine will be putting out.
.....unless there are more deals on the LS 364/440 that can't be ignored!???
oh...and yes, I'll have a build thread! I haven't bothered with it for phase I...which was to strip down my '72 and my '68, and install my '68's body on the '72. Now I can strip down the rest of the '68 chassis, get it powder coated, and begin the build. In the end it will be all new as this truck will be mine for many, many, MANY years to come.
Kurt -
