Old 11-08-2007, 08:37 PM   #26
jeffnohio
jeffnohio's Avatar
Re: Aluminum polish...
Mothers Billet Polish rocks!
Jeff
1967 GMC 3/4ton LWB, Orginal Straight 6, 4 on the floor Project truck
jeffnohio is offline   Reply With Quote
Old 11-09-2007, 06:10 AM   #27
chris71
chris71's Avatar
guys since this thread has been popular is there anyway that we can set up a poll? so people can vote on there favorite polish? im afarid i dont know how to set one up.
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 11-09-2007, 07:53 AM   #28
impala_631
:( BYEBYE :(
impala_631's Avatar
Originally Posted by Huck View Post
The trim is anodized and that has to come off first (try oven cleaner but don't let it sit--wipe in on then wash it off) then super fine steel wool and then polish. Grills, trim, etc. Use a power buffer with polish ----.
this is true, but the process can be quite involed, you can sand the anodizeing off will be the slowest, or the oven clean can speed things up, but the best is a chemical called LYE, found in alot of drain decloger type stuff, the coustic soda will stip the anodizeing off in about 15-60 minutes, it will then leave the metal really dull and you can wet sand it then hit it with the buffing wheel and compound and finish off with a mothers type polish, it will look like a mirror when you are done, the only thing is that you will want to hit it with a sealer like zoops to keep it from oxidizeing as air will cause the finish to dull quickly
impala_631 is offline   Reply With Quote
Old 11-09-2007, 07:55 AM   #29
impala_631
:( BYEBYE :(
impala_631's Avatar
also theres a killer paste that we use at work called simichrome, it can be found on ebay sometimes and it will make aluminum shine quickly, check it out
Old 11-09-2007, 09:16 AM   #30
ChaseDale3and8
ChaseDale3and8's Avatar
I have used Wenol metal polish for years with good results. I like it a whole lot better than Mothers. It is a paste that comes in a tube. Don't know if any of you have tried it or not, but I use it on my Powerball on my wheels, and it keeps them looking great. A little bit of Wenol goes a long way. ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 11-09-2007, 11:18 AM   #31
pmpski_1
pmpski_1's Avatar
I've had great results with Flitz.
pmpski_1 is offline   Reply With Quote
