Re: Need some transfercase ID help.
not gonna swear to it but kinda looks like a
203,these guys here will tell you for sure though. ![]() |
![]() Join Date: Mar 2003
203-----and with the locking hubs on the front, it probably has a 'part time kit' in it.
Its lookin' like a Blazer!
Should I stick with this x-case or search for a 205? I'm building this truck for a driver. Probably won't see 4x4 much.
I would go with a 205 if it is just going to be a driver.
http://www.cardomain.com/id/rcflyer1234 http://www.youtube.com/user/liftedtruck77 |
I dont know why not.
![]() Join Date: Apr 2000
no wrong splines.. needs to be an auto 205
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
![]() Join Date: May 2003
If the 205 is from a standard and you want to put it behind a th350 you'll need to replace the 205's in-put shaft and the adpt that goes between the trany & t/c. Or you could buy an special adapter from Advanced Adapters Inc. that will work with the two different splines. (Yes the splines are different.)
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
I'd use the NP205...Then you won't have any driveline issues (since the truck had a 205 originally) than you probably will with the 203.
