Old 01-06-2003, 05:13 PM   #1
HvyChevy454
Slowly getting CRSS...
HvyChevy454's Avatar
TH400 and TH350 Similarities?
Are they the same length, short shaft or long?
Is the trans x member mount in the same place?
Will the torque converters swap?
Will the yokes swap?
Got a Th400 w/ a 2200 converter behind the 350 in the s10 daily driver
Got a Th350 w/ 1200 converter behind the 454 in the 72 weekend driver
I want to see if i can swap em w/ out much trouble?
-Nic
Lutz, Fl
My Team Website
The Heavy Chevy Website
  • 72 Cheyenne 10 LWB GM 12-bolt 3.08 w/ Auburn Posi
    91 454 Edel Performer RPM Intake 750 cfm carb Comp Cam 268/.495 Hedman Headers Dual 3'' Exhaust
  • 71 Cheyenne 20 4x4 Fact. A/C PS PB Tilt Currently in the works...
Speak Softly and Carry A Big Block...
There is No replacement for Displacement...
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
HvyChevy454 is offline   Reply With Quote
Old 01-06-2003, 11:46 PM   #2
HvyChevy454
maybe i shoulda posted this on the trans board?
-Nic
Lutz, Fl
My Team Website
- Mario Andretti
Old 01-06-2003, 11:56 PM   #3
crazy longhorn
Fabricate till you "puke"
A short tail 400T is approx 11/16 longer than a short tail 350T. The slip yolks are a different size, & the trans crossmember locates in a different place. the converters will swap. TCI has case dimentions..... http://www.tciauto.com/tech_info/trans_dims.htm
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-06-2003, 11:57 PM   #4
Blackhawkdc
440 american Horses
Blackhawkdc's Avatar
Re: TH400 and TH350 Similarities?
I'm not sure about length and crossmember positions. But I'm pretty sure that the torque convertors are not the same, and the driveshaft yokes are not the same.
Seth Petro
1969 Chev Short Step
425hp 350, TH400, big tires, fast truck
1979 Pontiac Trans Am
1991 Saturn SL1 - gas mileage! (and free)
1977 Buick LeSabre - for sale
May America bless God, and may God bless America
Blackhawkdc is offline   Reply With Quote
Old 01-07-2003, 12:09 AM   #5
crazy longhorn
The tork converters are not the same, the 400 generally had a larger dia converter......they will swap as long as the 350 isnt a lock up trans,& & you have both patterns on the flexplates. I have run the smaller dia converters on the 400t(thats usually what you get with a mild aftermarket verter)
Old 01-07-2003, 12:27 AM   #6
HvyChevy454
gracias crazy
-Nic
Lutz, Fl
My Team Website
- Mario Andretti
Old 01-07-2003, 12:38 AM   #7
crazy longhorn
you are welcome
Old 01-07-2003, 11:09 AM   #8
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I took my 400 to my transmission guy and he actually recommended putting the 350 torque converter in it rather than the 400. As crazy longhorn said, that gives you the extra performance..
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 01-08-2003, 12:17 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Yup, I had to install a TH400 verter into my Th350 so I could run it behinde the caddy engine.
The caddy only has TH400 holes drilled in the fly wheel.
Crazy, you think this will hurt my theoretical stall? It's all stock, so it's not like I had alot of stall to lose there.
Old 01-08-2003, 12:36 AM   #10
crazy longhorn
I dont think it will hurt you too much longhorn, with the larger cube eng, & the gears in that 1 ton. The 70 delta that I drove home (455 /2brl) had a 400 t with the large verter.......it would boil the hides at will!
Old 01-08-2003, 12:37 AM   #11
mikep
Used to have a truck
mikep's Avatar
350 and 400 torque converter. Same thing. Sometimes the bolt patterns different. Sometimes its bigger in diameter depending on what vehicle it was under more than the type of tranny.
No truck :-(
mikep is offline   Reply With Quote
Old 01-08-2003, 03:15 AM   #12
wxman1
Can somebody educate me on what a stall converter
is and why its important?
Jim
Mt Juliet, TN
wxman1 is offline   Reply With Quote
Old 01-08-2003, 03:21 AM   #13
Project1970
14.1 @ 96MPH
Project1970's Avatar
All converters are 'stall' converters - the difference is whether they stall at stock speed (roughly 1500RPM) or higher.
More or less, the stall speed is where a torque converter really 'bites'. You only need to worry about it if you're running a hot engine that doesn't have a whole lot of bottom end, or doesn't like to idle much. A stock converter, you'll generally have a hard time holding the vehicle still if you try to get the RPMs above 1500 or so...the higher 'stall' a converter is advertised with, the higher RPM you can do before it'll really try to move.
More or less...it's how guys with autos launch a vehicle at anything higher than 1800RPM.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
