WTB 71-72 Front suspension hub to hub + X-member In CA
I am looking for a complete 5 lug disc brake crossmember from '71-72 2wd pickup. Hub to hub with coils, upper and lower a-arms, calipers, spindles,etc... In california please
Blazer Project |
Born Psycho
![]() Join Date: Feb 2001
Bill at vintage chevy truck in fremont, ca. (510) 651-5874 will have what you need if you can't find anything closer.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
Re: WTB 71-72 Front suspension hub to hub + X-member In CA
Jerry, Thanks a bunch.
Blazer Project |
![]() Join Date: Apr 2004
Do I smell a 2wd blazer conversion in the works!
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Truckin' Krazy
![]() Join Date: May 2000
Got the complete setup in phx AZ $200 if you want to make the drive.
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! |
Man...just moved from there. Do you have a photo?
Blazer Project |
Just out of curiosity why couldn't you do a 73-87 conversion. The crossmember is dirt cheap and should be plentiful around your area. That way you could upgrade to the 1 1/4 heavy duty brakes. Parts are cheaper also. Just an idea.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
I think because the 72 bolts right up. Am i correct? Also, is the 73+ the same width as the 72-71?
Blazer Project |
