Old 11-15-2007, 10:12 PM   #1
odog
odog's Avatar
67 K 20 17inch split rims
On my 67 K20 I have 17 inch split rim wheels. I got the truck from my father in law. His dad bought it new in 67. They never changed a thing on it other than the steering box, which is a whole other question. Are these truly stock wheels, did they offer such a thing back then? I would like to keep them as they are kinda cool.
odog is offline   Reply With Quote
Old 11-15-2007, 10:22 PM   #2
Ace in the hole
Re: 67 K 20 17inch split rims
Are you sure they are 17"? I have the original split rims on my 1970 k20 and they are 16.5" Either way I would say they probably original.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 11-15-2007, 10:25 PM   #3
odog
odog's Avatar
Yeah I'm pretty sure. My father in law said they always had trouble finding 17" tires for it. I looked at the number on the tires, 7.5 - 17. Guess they are stock huh
Old 11-15-2007, 10:27 PM   #4
Ace in the hole
Also, search around for info on split rims. You will find when you want to get new tires that only a few tire places will deal with them because of the dangers involved when seating the tires.
Old 11-15-2007, 10:43 PM   #5
Truck tire places do split rims.You just need that cage to be safe.Yes,they did make larger rims in the `60s for 4wds.UPS ran Chevys and they ran the tall rims.
Old 11-15-2007, 10:48 PM   #6
67_C-30
I have a radical idea!
67_C-30's Avatar
'67's have a lot of carry over parts from older models. and its possible they are factory. My '67 C-30 came factory with 17.5" 1 piece budd wheels, which are not real common. You can buy the reproduction 7.5 - 17 tires from the site below.
http://www.hotrodhanks.com/products/tires
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 11-16-2007, 04:23 PM   #7
JAKES 68GMC
Aluminum slot wheels rule...
Yeah they're stock, my 68 had them. I've got about 10 spare ones kicking around.
JAKES 68GMC is offline   Reply With Quote
Old 11-16-2007, 07:18 PM   #8
BurnoutNova
BurnoutNova's Avatar
yes your phillips 66 will turn you away... but like special-k said split rims are still used on farm equiptment and on semi trucks
BurnoutNova is offline   Reply With Quote
Old 11-16-2007, 07:58 PM   #9
72freak
Rottenwood Garage Member
72freak's Avatar
Farm equipment yes.......true original split rims (suicide rims) I believe now are not legal for commercial application.
I have them on my 72 GMC 5500 and the 68 C-30 dually. My commercial truck shop will do them but they wont air them uness they are in a cage or bolted back up to the truck and the complain every time I come in with them!!!
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 11-16-2007, 08:57 PM   #10
67_C-30
67_C-30's Avatar
Does you 5500 have the 20" funky kind that split in the center? That's what is on my '67 C-50 wrecker.
My trucks
Old 11-16-2007, 11:18 PM   #11
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
'67 Chevy, 1Ton w/17" split rims.
Please ignore the Ford wheels & hubcaps that the PO ran...but, he did save the originals. Pretty cool with those little "dog dish" hubcaps.
PICKMUP is offline   Reply With Quote
Old 11-16-2007, 11:30 PM   #12
factorystock
factorystock's Avatar
Yes, The 17" split rim wheel was always an option on 3/4 and 1 ton pickups up untill 1968.The 17" 3 piece could handle more weight than the 16" 2 piece and the 17.5" one piece wheels.Truck tire shops only for working on them. This country was built with split rim trucks hauling millions of miles long before the tubeless rims came on to the scene.Many construction trucks and trailers still use them today. In the sixties, the GM 15" 3 piece (1960-1965) was recalled because they broke when overloaded.The solution was to replace them with 15" 2 piece rims.The other designs were safe if properly installed by trained personnel.
factorystock is offline   Reply With Quote
Old 11-17-2007, 04:27 AM   #13
72freak
72freak's Avatar
Yes..........Thats a real original style split rim........(suicide wheel)
Old 11-17-2007, 04:42 AM   #14
72armyswbtruck
72armyswbtruck's Avatar
The military still uses them, as long as they are in a cage when aired up they are fine. The reason they were called suicide rims was because people would not get the rims seated properly and would sit on the rim while airing it up. the inner rim would blow off sending the person sitting on the tire up into the air and into peril
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 11-17-2007, 08:43 AM   #15
As mentioned,there are two types with the later design being more safe.I had a tough little truck in CA.A `55 2nd 8-lug shortbed with 15" split rims.On unpaved roads hauling loads the clincher style become the "split" rim and the split rims hold up.As the roads became mostly paved the split rims became less popular,not so much about safety.I never really heard about them being so unsafe until they stopped beind offered on new trucks.Maybe once radials started being used on trucks had something to do about it.Although,UPS trucks running these rims were some of the first trucks I know of that started using radials (Michelins,the first radial).My dad bought 16" Michelins for our Land Rover in`69.That was the early days of radials.
Old 11-18-2007, 07:07 PM   #16
factorystock
There were many wheel options from 1960 to 1968 for 3/4 and 1 tons. The 19.5" one piece wheel would be a great choice on low geared trucks. This 19.5 wheel and tire combo is 33" tall and has a period correct tubeless Michlin X radial.It allows you to keep the small dog dish hubcaps, and run a modern tubeless radial.Tire shops will now love you.
Old 11-18-2007, 07:20 PM   #17
factorystock
Here is a view of the size 8R 19.5 = tall and narrow.
Old 11-18-2007, 08:22 PM   #18
eedgell
It's the air up here
eedgell's Avatar
Any Pictures of said 67' K20? I would love to see those rims! As well as the rest of the truck.?
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 11-18-2007, 08:36 PM   #19
odog
odog's Avatar
I will try to get pics of the truck and rims on tonight or tommorrow. havnt had time to do much to it lately. Have been busy with work.
Old 11-18-2007, 08:52 PM   #20
too much stuff
Roadtrip!
too much stuff's Avatar
I have a 72 custom camper truck with 17" rims on it. I will have to check the tag and see if it says anything about them.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 11-18-2007, 10:19 PM   #21
odog
odog's Avatar
Ok here are a few pics, my camera battery crapped out on me but I will get more in the morning
Old 11-18-2007, 10:21 PM   #22
odog
odog's Avatar
The front wheels are off an old international 3/4 pickup. Had to have something to drive it back from Montana on. Back ones are the splits and two more by the garage.
Old 11-19-2007, 07:37 AM   #23
72armyswbtruck
Howdy ODOG from the western part of the state
Old 11-19-2007, 11:45 AM   #24
odog
odog's Avatar
Hey hows the western part of the state doin. Maybe going that way next month, may have some rock to blowup towards Kuna.
Old 11-19-2007, 06:22 PM   #25
BurnoutNova
looks like theres only 1 towhook on the front? it looks like a 69-72 also
