60' frame vs 66'
dudes, do 60' frames have different cab mounting points than say 66'? the reason i ask is the 60' has the torsion bar front end vs the standard a-arms on a 63' on up. i have a 59' that is on a 63'-70' frame and have a sweet running RUSTY 60' i was thinking about using under the 59' can anyone tell me the difference? thanks
Still Truckless!
Re: 60' frame vs 66'
Dunno bout the cab mounts but i know the bumpers and bed mounts are different between the 60-62 and 63-66
~James ![]() ![]() 2009 Hyundai Sonata<~~Wife's sedanomatic 1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive ![]() ![]() ![]() ![]() |
60-66 Nut
As already stated the bumpers are different, plus the front cab mounts are different, but just need to drill holes. I believe the rear cab mounts are the same. The bed mounts are different, but there again just need to drill holes. I do believe the radiator support mounts are the same too.
UCA63
while we're on this topic,i have to replace my front cab supports('61 gmc),can i weld in 63-66 supports then mount the cab on a 63-66 frame???
thanks T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
60-66 Nut
Yes you can...you could also do it with the '60-'62 cab supports....just have to drill the bolt hole. The shape of the front cab supports are the same from '60-'66. They have a double step in them that will work on either the '60-'62 frames or the '63-'66 frames. The difference is the location of the bolt hole for the cab mount assembly.
