Old 11-18-2007, 08:54 PM   #1
Critter
Future TOTM Winner
Critter's Avatar
Dumb temp gauge question…
I looked around a little but couldn’t find an answer. Exactly what temperature values do the vertical lines represent on these original temp gauges?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 11-18-2007, 09:19 PM   #2
BLUE THUNDER
BLUE THUNDER's Avatar
Re: Dumb temp gauge question…
A little less cooler and a whole lot hotter? As long as you're in the middle you're o.k. See you guys on Sunday.
BLUE THUNDER is offline   Reply With Quote
Old 11-19-2007, 12:11 AM   #3
Critter
Future TOTM Winner
Critter's Avatar
Not quite the precision that I was looking for...
Old 11-19-2007, 12:51 AM   #4
dan42
dan42's Avatar
Those things are 1 step above idiot lights, imo...
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 11-19-2007, 09:02 AM   #5
Yukon Jack
Yukon Jack's Avatar
Critter, grab your wife's meat thermometer from the kitchen and put it in the radiator and what the guage and it. I find these gauges vary from truck to truck. My K5's gauge is very near the right side when the temp is actual 180, while my 69's was about in the middle at 180.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-19-2007, 11:30 AM   #6
1970cstblazer
1970cstblazer's Avatar
Talking Re: Dumb temp gauge question…
At 180, my gauge is just over 1/4 above the C mark. The oil pressure gauge is right on.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 11-21-2007, 05:06 PM   #7
mister.freeze
mister.freeze's Avatar
It depends on your temp sender. I melted one in the Fox and it shorted itself out reading all thew way hot. The replacement couldn't go pat 1/2, so I got another. I'm sure there are different temp ranges like thermostats, but the guys at the parts counter couldn't tell me which was which. I can play with mine on the Fox because the radiator fans are on a manual switch. With my current sender and a 190 thermostat, the needle hovers about 1/8" pat that first hash with the fans on.
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
