Old 11-20-2007, 01:09 PM   #1
Rokcrln
Rokcrln's Avatar
Need info from the blazer crowd please!
Ok guys what I need is info on how well the top seals to the door glass. What have you done to make it better or what have you found that works? I am in the designing stages of a show built Blazer that will see plenty of road use after a year or so on the tour. When that day comes I don't want to be wishing I had done somthing different due to wind noise or water leaks. I feel this is part of the reason they went to the half top in late 75. Any input and or pic's would be great!
Kevin
LFD inc.
Rokcrln is offline   Reply With Quote
Old 11-20-2007, 01:24 PM   #2
onetonk5
Cereal Killer
onetonk5's Avatar
Re: Need info from the blazer crowd please!
top/front corner of glass and top leaks pretty bad as does back rounded corner of door glass.
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
Old 11-20-2007, 05:22 PM   #3
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
I haven't run mine in the rain, but I always thought the window rubber was a little too thin. Maybe if you could get some wider/thicker channel and put that on the top, it might make a better seal?
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 11-20-2007, 06:10 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
They really don't seal up well, and I haven't got anywhere near the mechanical skills you do, so I haven't figured out a way to make them seal. Good body mounts help, but the top will sit slightly different on the truck each time you take it off and put it back on. If you can figure a sure way to align the top exactly, you could probably get it to seal properly each time you replace it.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-22-2007, 07:46 AM   #5
Rokcrln
Rokcrln's Avatar
So it sounds like in the best case it is only so so. I am debating doing somthing with truck doors to get a good seal and this will be on a 2WD that wil not see much topless time if any so it still would look just fine. I am not going for the roadster look even know I live in Ca I burn way to fast and like A/C.
Kevin
LFD Inc.
Old 11-22-2007, 09:55 AM   #6
raggedjim
raggedjim's Avatar
I think a good fiberglass guy could make a channel on the top that held the regular truck window channel felt so that when the the window is rolled up it fits in the channel.
Or possibly the old 57 chevy hardtop style flap down trim that pops into place when the door is shut.
There are 2 ideas I could NEVER make work, but someone like you...
Rg
raggedjim is offline   Reply With Quote
Old 11-22-2007, 09:57 AM   #7
cstanley
cstanley's Avatar
exterior door/window caulk from lowe's?
that's what was keeping water our of mine when i got it.
who knows, i might put some back on when i replace it in a few weeks... once a year isn't too bad to apply it, right?
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 11-22-2007, 10:22 AM   #8
Rokcrln
Rokcrln's Avatar
Rg
Only problem I see with the felt in the top is you would need to leave your window down a crack to shut/open the door. Our old Mini Cooper had a feature that teh windows would lower a 1/4" to alow this to work then once the door was shut it would pop back up. Worked real well. I want to check out a few euro cars to see how thewy are done but I don't think I could afford the rubbers to make it all happen
While caulking would and does work great I don't think the judges would look to kindly on it
If I use the full dorr top I would be able to make it very smooth with the rest of teh top. But I like the look of teh Blazer topless with stock doors so who knows!
Kevin
LFD inc.
Old 11-22-2007, 10:54 AM   #9
bouncytruck
SKINNY TIRES RULE!
My buddy's Boxster has the same feature that lowers the window slightly when you pull the door handle. Works well and hardly noticable. I've seen the same thing on a few other cars that don't have door glass frames.
bouncytruck 1972 K5
Old 11-22-2007, 11:08 AM   #10
raggedjim
raggedjim's Avatar
OK, I've crawled out of the box... How about making a removable truck door surround? take it off when you're topless and put them on before you put the top on?
Or maybe completely removeable windows like the old 1949 Dodge Wayfarer Roadsters?
I'm on a roll...
Rg
Old 11-22-2007, 12:35 PM   #11
Musclerodz
kevin, you and I are thinking the same thing but I am wanting to do it with a one off soft top. More "convertible" like. I have plans on using a single wall top as a header bow.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 11-22-2007, 01:08 PM   #12
Rokcrln
Rokcrln's Avatar
Mike
Yes mine wil be a one off top as well but a full (steel or alum) hard top. If you are thinking about using full doors for better seal then use the top off a truck and cut it down for the soft top to fasten to.
Kevin
LFD Inc.
Old 11-22-2007, 02:02 PM   #13
jaros44sr
jaros44sr's Avatar
Maybe you could cut a better fitting window glass, it's flat. Pin the hardtop in several locations, like Bouncy said. My factory hartop on my TR-6 is of the same design, and I drove thru the winter, traction stank in the snow...
I plan to build mine outta wood like the Morgans
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-22-2007, 06:43 PM   #14
onetonk5
Cereal Killer
onetonk5's Avatar
Soft top leaked much worse than hard top. Its all design issues that have cause leaks...also cause people to LOOK when top is off. I dont see a sealed blazer/stock(good) look in my future. Hopefully top will be well massaged/painted and left to sit while I cruise/Park undercover!
Old 11-22-2007, 07:50 PM   #15
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
Hey Kev you should Check into the New Volkswagen convertibles the window pops down when open and the when you close it it snugs up. This would look slick with a set of power windows.
Angelse68cal is offline   Reply With Quote
Old 11-25-2007, 12:07 PM   #16
Musclerodz
Kevin
LFD Inc.
Thought about that but I don't want to have the doors impeding my view when the top is down. So many choices
Mike Redpath
Old 11-25-2007, 01:22 PM   #17
ClassicJimmy
FNG to resto/mod world!
ClassicJimmy's Avatar
I've been preping a door for my Jimmy & as I work on it I have ideas rolling thru my head. One of the original ideas was to have a one-piece door window - get rid of the wing window. Everyone on the board said there hasn't been a way to do it, because there is no support for the window. Seems to me that there are a lot of convertibles out there with one piece door windows & don't have these issues. I think with the seals & using the available technology from today's convertibles, someone might be able to kill two birds with one stone. I personally haven't started the research, but that was the direction I was going. Good luck & I'm subscribed! I'll be sure to post anything I can come up with too.
71 GMC Jimmy - under construction
75 GMC K25 Sierra Grande - under deconstruction
92 Chevy K2500 ECSB - sold
04 Nissan Titan ECSB Off Road - sold & missed
13 Ford F-150 Ecoboost (work truck) - sold
16 Ford F-150 Ecoboost (work truck)
ClassicJimmy is offline   Reply With Quote
Old 11-25-2007, 07:20 PM   #18
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Interested in where this thread is going
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-26-2007, 12:27 AM   #19
Rokcrln
Rokcrln's Avatar
Right now it is going right here! I am just asking so I can figure out what direction to go with my 2WD when I get started on it. But as of Wensday that will be put off a bit longer I just picked up a clean 63 SWB that is going to get a quick build done in the near future as a joint project with another board fabricator
Kevin
LFD Inc.
Old 11-26-2007, 03:01 PM   #20
arcticspade
I saw a guy make a truck-convertible at a show. He did the “felt option” on the seal to the top and a different weather-strip at the back that had a channel in it to drain the water to the rear and down. He went with the power windows and set the relay in them to do the same thing (where they slightly role down when you open the door). The top was like a half cab old k-5, kind of… similar at least. Granted his was a pure show truck and the top that he modified was only on half the time (at most) and who knows about day to day functionality. He said he originally made the relay so it went all the way down because he wanted the felt channel at the rear of the glass as well; he tried it for a while but forgot to wait for the window to roll all the way down once, he swung the door open, and ended up with the door glass on the ground and in his lap.
arcticspade is offline   Reply With Quote
Old 11-26-2007, 03:05 PM   #21
arcticspade
I'm on a roll...
Rg
I'd buy it! Best of both worlds.
