05-16-2002, 07:37 PM | #1 |
Bed Placement
What's the correct distance between the cab and the bed?
05-16-2002, 08:10 PM | #2 |
Collector of rusty Items
The top of the bed has a rolled piece. That rolled piece should be about an inch away from the back of the cab.
Measure in the front bed below the center of the rear window. it should be pretty uniform. ------------------ Scrub 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. [This message has been edited by Scrub (edited May 16, 2002).]
Scrub Sisters, Oregon - Home of the Sisters Rodeo. 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. |
05-16-2002, 08:53 PM | #3 |
I'm confused - but I get that way easily.
The corners of the cab are rounded. Where do you get your measurements from? Do you shoot a straight line from the back of the cab and measure from the rolled lip on the box? Maybe a better way to ask is, how far back from the center of the cab to the box? Thanks for the help. |
05-16-2002, 08:55 PM | #4 |
Sorry. Having a dumb attack.
You already answered my question. Thanks Measure in the front bed below the center of the rear window. it should be pretty uniform. |
05-16-2002, 10:42 PM | #5 |
If it is too tight it might rub or bind between cab and bed. I've seen fingers pinched between top of bed front and cab when truck flexed a little on straight trucks. I measured 2 straight stock unhit trucks just now. 1st is a 71 3/4 ton 2 wheel drive, gap measured 13/16th - 7/8". 2nd is 72 1/2 ton , 2-wheel drive measures 7/8- 1 1/4". Neither variation is noticeable. I would set in this range and try to get it as even as possible.
Bob |
05-16-2002, 10:55 PM | #6 |
cheyenne10 I think you are right, around an inch is about right. I would look at the gap down both sides also and see if it is even as well as the gap between the cab and the front of the bed.
