Old 11-21-2007, 10:47 PM   #1
BCOWANWHEELS
speedometer cable lube question
anybody know how to lubricate a speedo cable correctly for the 67-72 tks ?
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 11-21-2007, 11:09 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: speedometer cable lube question
Bob,
I don't know if they still make it but there used to be a speedo cable lube in a small plastic dispenser, available at the auto parts stores. You took the cable loose from the speedometer and squirted it down inside the housing.
LockDoc
Leon
Old 11-21-2007, 11:20 PM   #3
SactoJim
SactoJim's Avatar
Basically the stuff you can get at NAPA is powdered graphite.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 11-22-2007, 12:12 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I have used white lithium grease with zero problems -- however, I understand it's not really the best thing, as it can get a bit too gummy. Apparently graphite is a better lube. Of course you should pull the inner cable out of the housing and clean it thoroughly before lubing...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 11-22-2007, 12:25 AM   #5
BCOWANWHEELS
stocker,
do you pull the cable out from the top or bottom ? i,ve used white grease for years on tach & speedo cables but never did a 67-72 chevy tk. cable. if i tilt the dash back and unhook the cable can i pull the inner cable out then ?
bob
Old 11-22-2007, 12:32 AM   #6
Andy4639
Old member
Andy4639's Avatar
You should be able to inless the clip out on the fire wall has it to snug. Must cables want let you pull the dash out without having it disconnected at the speedometer.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-22-2007, 12:29 PM   #7
BCOWANWHEELS
Thanks Andy
Old 11-22-2007, 09:17 PM   #8
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
The new speedo cable I bought came with instructions that specifically said to use the graphite spray lube but be careful... It will make a mess and even stain your skin. It's generally just a PITA to clean up if you get it somewhere other that where it's intended to go. My experience with this stuff went someting like this... Insert the small extension tube into the end of the speedo cable housing, press down on the actuator, tube shoots out of the end of the valve getting spray lube everywhere. As you can imagine a few four letter words were used. LOL
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 11-22-2007, 09:29 PM   #9
BCOWANWHEELS
i,ve used white lithium grease for cables for over 30 yrs in semi trucks and its what i,am gonna use in my 72 pickup if i can get the inner cable out of the outer housing. thanks
bob
Old 11-22-2007, 11:26 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Sorry I didn't get back sooner, Bob... It's been many years since I lubed my truck's cable, but I disconnected it from the back of the speedometer and pulled it out. I recall it being a bit of a pita to get to -- but I can't remember if I loosened the dash panel or not...
- Mike -
RIP El Jay
