Old 01-07-2003, 08:38 PM   #1
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Starter Question
I am switching from the cast iron bell housing to the aluminum type bell housing. What is the part number for the starter that goes with aluminum bell housings?
Ben
67Fleetsidedream is offline   Reply With Quote
Old 01-08-2003, 01:34 AM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Should be the same starter. It bolts to the engine not the bell.
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 01-08-2003, 02:21 AM   #3
crazy longhorn
Fabricate till you "puke"
The trucks ran a 168 tooth flywheel/flex plate(14" dia). The starter that fits the auto trans apps, or alum bell stick , will have a staggered boltpattern. If you by chance you have the smaller flywheel(153 t, 12 3/4"dia) the starter has a straight across pattern,& both starters bolt to the block as posted. If the truck starter that you have is good, you can change the end housing & bolt it to your block......arent Chevs great! i cant help on part #, but good luck......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-09-2003, 02:26 PM   #4
67Fleetsidedream
Thanks for the info. I am going with a T56 6 speed once I get all the detailed problems worked out. I just wonder what else I am going to have to change to make this work.
Ben
