Old 11-23-2007, 01:00 PM   #501
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Project: "Junkyard Resurrection"
Sweeet hooooks..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-27-2007, 08:39 PM   #502
1969k10stepside
More body work done..Still cutting out the rusty bottom half of the cab.The drivers side is almost done..I have to finish the floor/cab supports on the other side so I can get the cab back down on the frame to put on the fenders and check alignment before the rockers/cab corners are all in...Do I wish I had a better cab to start with? Yes..but this cab was free,and only have $150 max in the cab...Would I pay someone a outrageous amount to do the same work? No...It's easy if you can weld,have the tools,the place,and the knowledge to piece a truck together...I wonder how much would be in the truck by now if I took it somewhere and payed them to do the work? I'd say 15k as is now,before paint,and body work is done...I had the person over who will probably paint the truck,he looked the cab all over before I started permanently welding stuff in and he said it looked alright so I can't be doing too much wrong...
1969k10stepside is offline   Reply With Quote
Old 12-03-2007, 11:45 AM   #503
1969k10stepside
..It was only a matter of time till they were put on.
Old 12-03-2007, 11:48 AM   #504
CUSTOM/10
CUSTOM/10's Avatar
Is that how they go ??? Guess I"ll have to turn mine around!!!
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 12-03-2007, 10:00 PM   #505
1969k10stepside
Guess so..I don't know which way they are suppose to point though.I think they both point out...
Got the cab lowered back on the frame...Got the fenders on so I can align the rockers before welding them in..I finished cutting out the floor and got one of the front cab supports in..I only have one left to do,put in the floor,and weld everything together...I got the tranny linkages hooked back up,the steering hooked back up,and had a minor oil leak from the pan due to a loose bolt,so I tightened it..
Hey Gary,don't you just love these short 4wds? I just have to remember after this one is done I've got the '72 GMC K1500 short step to work on..and by the time it's done I'll have another to work on..
Old 12-04-2007, 08:09 PM   #506
prg machine
prg machine's Avatar
Originally Posted by 1969k10stepside View Post
Here is what it may look like in the end.This was see ten's K10 I changed the color of to a dark blue.It may have a two tone,or may just be one color with no trim..I can't decide.
Attachment 313921
I like the flat black better
prg machine is offline   Reply With Quote
Old 12-04-2007, 08:38 PM   #507
CUSTOM/10
CUSTOM/10's Avatar
Yes I do !!!! I have owned 4 70-72 SWD 4x4's since 1983 and love them !!!
It's more like an adiction. Their built tuff, great looks, I guess it's like finding the right woman, you fall in love with them !!!
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 12-10-2007, 09:43 PM   #508
1969k10stepside
Still doing body work in my spare time...Got the floor almost all welded in.The rockers are lined up,and are ready to be welded.I still have to get the passenger side cab corner lined up and then it and the rocker can be welded in.Passenger side floor is in,and drivers side is ready to go in.
Old 12-16-2007, 03:54 PM   #509
1969k10stepside
Cab corners and rockers are done..Just have to do a little trimming on the drivers side floor pan,weld it in,and it's done..Got the front driveshaft on today..It just needs paint.
Old 12-29-2007, 08:23 AM   #510
1969k10stepside
Still doing body work..mainly just getting things to a point I'm satisfied with.The passenger side is about 95% done and the drivers side is about 80% done..I just got tired of doing body work and did some work on other vehicles like the '72 Blazer..I did finally buy a 650 Edelbrock carb but don't have it hooked up.I haven't heard the motor run with it though since I've got the tank out since I'm still welding in the cab.
Old 12-29-2007, 08:50 AM   #511
heavy71chevy
heavy71chevy's Avatar
man that rigs come along way...very nice work freind...take pride in that beauty
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 12-29-2007, 01:56 PM   #512
1969k10stepside
Yep,it's came a long way but I hope to go alot farther with it!
I went back out to the shop and did some more work.I never painted the pulleys and fan so I took them off and painted them.I also painted the front bumper brackets since I didn't before.I ran out of paint though so I didn't get the driveshaft painted.I hope to get it painted this weekend.
Old 12-29-2007, 02:46 PM   #513
FRENCHBLUE72
PROJECT 7DEUCE
Looks good keep up the good work..
MEMBER #6377
Project "7DEUCE"
Old 12-31-2007, 05:52 PM   #514
1969k10stepside
I got the carb bolted on today.But the kickdown and throttle linkages won't work with the stock brackets.I guess I'll look for some that do.I did get more paint today so I've got some painting to do on driveshafts,bumper brackets,and some other stuff I haven't painted.
Old 01-14-2008, 01:57 PM   #515
1969k10stepside
Went to Advanced Auto while I was in town today (Looking at new Z71s..) and got me the Edelbrock throttle/kickdown/cruise control bracket.I put it on but I had to trim one corner.I found it kind of odd I had to do that since the bracket,intake,and valve covers were Edelbrock but oh well...Got it bolted on and now I have a throttle and the kickdown works.I finished painting the driveshafts.I finished the passenger side except for one spot around the kick panel and then I ran out of welding gas.Got the tank filled today..I am almost done with the drivers side rocker and cab corner.Just some welding and grinding and they will be done.Then finish welding around the floor and finish the front cab support.Both doors open and shut easily now!I hope to have some primer on this by the end of the month.
Old 01-14-2008, 02:19 PM   #516
1969k10stepside
BTW,here's pics of the 2 current projects.They both started as $350 4wds,but the Blazer was complete and running.As soon as I get the body work done and the body in primer I'm getting the blazer in the shop and getting the 4" lift installed I've had sitting in the shop for a few months.The only thing I've done to the Blazer since the pic was taken was putting the top back on for the winter...Then on the back burner is the '69 K20...it's been waiting on a motor for 2 years and finally bought some parts for the motor last week.I'm in no hurry on it though.
Old 01-14-2008, 03:01 PM   #517
ChaseDale3and8
ChaseDale3and8's Avatar
Your truck keeps looking better all the time. I'll be watching your other builds as well. They will all be great looking trucks when you get done! ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 01-14-2008, 05:33 PM   #518
1969k10stepside
10:30 Update..Going to try to start the truck tomorrow.Hopefully it does start.I'm going to run to town tomorrow and get new spark plugs for it since they need replaced..Almost got done with the cab.It's pretty much all done now fixing rust wise.I just need to do a little bit more welding in a few spots and then move on.The only other real body work I have to do is fixing some dents in the fenders,bedsides,and fixing a few small holes in the floor of the bed.
Old 01-15-2008, 02:31 PM   #519
1969k10stepside
Well,I didn't get it fired today.Mainly because I wasn't done welding in the cab so I couldn't get the gas tank in.I did buy and get new spark plugs in though.I bought part of the exhaust.I bought 2 and 1/2" thrush glasspacks.I just need to get the pipe bent so I can get it ran so it isn't so loud..atleast till they burn out.I can't decide whether to run the exhaust out the back or the sides..
Old 01-17-2008, 05:34 PM   #520
1969k10stepside
It's alive
I got my $10 column wiring adapter in to hook the van tilt wiring to the truck wiring,got the longer cab bolts on.Put in the gas tank and the seat.I put $15 worth of gas in it and then checked things over.Turned the key and it roared to life instantly.It runs alot better with the Edelbrock 1406 than it did with the q-jet.It has a exhaust leak on the drivers side,but that's expected when using headers.I'll get that fixed shorty.I also need to adjust the valves now that I can hear the motor and not just the noise of open headers..The truck does have a nice rumble through the thrush glasspacks though.My power steering pulley was bent so I replaced it but I don't have any pulleys turning except for the fan/water pump.The belt I bought to run the alternator/water pump/fan pulleys was too little.Eventually I'll have to get the a/c compressor mounted too...
Old 01-17-2008, 07:07 PM   #521
hgs_notes
GEARHEAD
hgs_notes's Avatar
Congratulations! Seems like it's been a long time coming, but that's only because I haven't touched my own projects in months.
hgs_notes is offline   Reply With Quote
Old 01-21-2008, 10:07 AM   #522
1969k10stepside
Well,I got the old dash pad out,the old radio (Being replaced with a CD player of course) and all the a/c components.All of that will be replaced.I also ordered inner fenders ($55 a piece @ local body shop).Plan is to bolt the body all together,Finish most of the body work,put some primer on it and drive it for awhile and then paint it when it warms up.
Old 01-24-2008, 12:45 PM   #523
1969k10stepside
Started bolting the bed back together.It had a few bolts holding it together but I got one inner fender for the bed cleaned and primed and re-installed.I took the passenger side bedside back down to bare metal to be primered too.It had bondo on it from where the lower trim would be to the bottom but there was no damage,just a few small dents..Someone just went crazy with the bondo.After I get the other inner fender cleaned,primered,and bolted back in I'm undercoating the bottom of the bed.Then clean the inside of the bed,fill a few small holes,and then primer it.Then I've just got to do some minor work on the tailgate which shouldn't take long,then primer it and be done with the bed till paint.The cab just needs some minor body filler around where the cab corners are welded to the cab to make the transition even.Then clean the doors back down to bare metal,pull a few dents,primer them and be done with them.One front fender has already been cleaned,and primered.The other still needs redone after pulling that one dent out.The cowl is ready for paint.The only thing I haven't really done anything with it the hood,which I can't decide if I'm going to use it,or get a cowl hood..I'm getting ready to buy the interior.Getting closer to finished..just about ready for paint and final assembly! Still a bunch of sanding to do before paint though!
Old 01-24-2008, 12:53 PM   #524
franky69c10
chevy runs deep
franky69c10's Avatar
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 01-24-2008, 09:56 PM   #525
estig70
estig70's Avatar
Eric
estig70 is offline   Reply With Quote
